![]() | Home > Technical (L322) > Suspension queries |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Once you hit 70 it drops into motorway mode!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Yes it drops itself ever so slightly, so little that you wouldnt notice |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Kruger - the manual should point this out but as long as you have not "locked" the suspension mode (by pressing the button on the circular suspension select knob) then it will drop and raise.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
. . . . I'm sure I've read it on here before that the "motorway mode" differs for different MY's ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
the 2002-2005/6 go down at around 65/70 mph and the 2006 onwards with the newer interior go down at 100 mph.. ... - .- -.
kruger2002 Member Since: 19 Jul 2013 Location: Newbury Posts: 70 ![]() ![]() ![]() |
aah... I'm not driving fast enough |
my bad - thanks Stan..!
Touchscreen cars don't have the motorway light... So, they do not lower at 65mph |
my touch screen range did Craig...
Wrong pic Stan, it's the square box in the middle (covered in your pic by your gear stick) that looses the motorway light on the left hand side... All the rest of the panel is the same from 02-07 but the motorway light left when the touchscreen was introduced... |
i did have this 'motorway' light Craig... |
Are you 100% sure Stan |
absolutely sure Craig..
