Home > In Car Electronics (L322) > Sat/nav questions
ryanr24
United States 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Sat/nav questions
Hello I have tried google but i keep getting more confused, I have a 2006 range rover and i was interested in a mkiv upgrade, but when I looked at my computer it had a dvd rom(which I thought the mkiv had) when i ejected the disc it was a random burnt cd-r disk, so i guess my questions are how do i find out what version I have? how to i upgrade to the newest?(cheapest way possible) Im also confused by this because i was reading that with the mkiv I lose off road nag(which i don't really care about) but I have it as an option currently.
Post #223822 19th Nov 2013 6:35am
I am guessing here but I think you have a touch screen model , am I right ?
If so your system was made by Denso not VDO and you need one of their discs made by Navteq
http://www.navigation.com/is-bin/INTERSHOP...logos&
The mk4 was or rather is a BMW upgrade for earlier Range Rovers with out the touch screen , It was never officially fitted. 2008 MY Supercharged
Post #223825 19th Nov 2013 7:55am
ryanr24
Yes I do have the touch screen exactly and thanks for the insight
Post #223828 19th Nov 2013 8:40am
TugRR
Hi -
I've an '06MY car with the DENSO system and I've just bought a 2011 disc for it. On UK cars the difference between this and the original disc is that on the later one you can't input addresses or postal codes whilst on the move. I presume there will be differences with your (US) disc anyway, but maybe this is an easy way to tell ?
Somebody will be along very shortly with more info no doubt !
Thumbs Up Where do you go after one of these . . . ?
Post #223844 19th Nov 2013 9:53am
Tug, the disk will not turn on or off Nav on the move my friend... It should be off from factory and I guess yours will have been turned on sometime in the past and replacing the disc has made your rom reboot/update hence loosing the facility... Thumbs Up
Post #223849 19th Nov 2013 10:08am
Paul, if you have 'nav on the move' enabled then using the 2011 disc wont affect it, that's what i found with mine anyway...
also nav on move can be switched on with the iidtool apparently.. ... - .- -.
Post #223850 19th Nov 2013 10:09am
Only on certain firmware models Stan... Thumbs Up
Post #223853 19th Nov 2013 10:15am
TugRR
Ah ! - like I said to ryanr24 - somebody more knowledgeable would be along shortly - thanks fellas !
On my previous car, changing the disc to a later one lost "nav on the move". On this car, I changed the disc virtually as soon as I got the car and now I think about it, I'm not sure if it did it or not - probably not from what you say Craig ?
I guess for ryanr34, he needs to know if there are any tell tale signs to let him know which disc he has ?
Post #223855 19th Nov 2013 10:18am
i'm not sure if there might be some info re the year of the disc in the hidden 753 menu..
@ Craig , sorry forgot to mention that Thumbs Up .. ... - .- -.
Post #223858 19th Nov 2013 10:23am
Im sure you can bring up a firmware/software code in a secret menu... I'm sure it will be in the wiki Thumbs Up
Post #223860 19th Nov 2013 10:23am
