![]() | Home > Maintenance & Mods (L322) > Stuck can't open vehicle |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Well the AA turned up after about 90 mins and as I went outside I pressed one of the remotes, hey presto lights flash and doors unlock. Repeated locking, unlocking (with drivers door open) several times and no problem. Car started first turn of the key, battery checked and said to have a full charge. Locked at home last night, unlocked this morning plus several tests and all ok so I guess a random fault or some kind of interference.
Sounds as if you need to take a large Faraday cage with you next time you visit that location.... .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
Robert, the door lock is a common problem on the FF , you can find out how to fix it via the forums search function.. |
Is this the fix that I need?
if you put the key in the door lock , turned it and the door didnt open then the cable running from the outside lock to the inner mechanism is broken, this means a door card off and the cable replaced...
I can open the door using either the internal or external handles. The problem I have seems to be with the lock (key in the door) that does not do anything when the key is twisted in either direction. The car does lock using the remote or the button on the dash, just don't want to be left with no manual ability to open to the car if the remote plays up again.
understood , then its the actual key lock which needs sorting as per the instructions you posted... |
Thanks, I will try tonight if I don't hear anything back from the dealer. There is a difference between knowing your sh!t and knowing you're sh!t
OK lock removed no problem but I could not find the screw shown in the instructions in the door. Photos of what I had out
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
1 out of 10 for your poor photography there |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
cheers for this post dude, had the same issue yesterday and had to pump the battery using the starter motor to unlock the car |
Thanks for improving the photo, the iPhone flash would either go gown the lock or on the door. I will have another look now I know exactly what I am looking for. There is a difference between knowing your sh!t and knowing you're sh!t
If it's working now you have it aligned properly, no point stripping it down again |
mines done and working now, i could see where it had been put back peviously that they hadnt alligned it ad it was sitting in the foam liner, works a treat now
