Home > Technical (L322) > No HDC and No Change of Transmission Range |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Any idea if this is likely to just be a faulty switch or something more complicated. No obvious error codes when scanned on iid. There is a difference between knowing your sh!t and knowing you're sh!t
22nd Feb 2014 1:33pm |
Assume it was all working OK before the panel swap?
22nd Feb 2014 2:19pm |
New central control panel and HDC and Low Range working again. There is a difference between knowing your sh!t and knowing you're sh!t
26th Feb 2014 10:55am |
