Home > Technical (L322) > Dead battery this am
funnyguy1
United States
I installed a new battery 2 months ago. This am went to start and ABS Fault light came on as well as the Green lo mtn light on the dash , then it would not recognize the remote key fob and then everything dead, no lights anywhere. noticed the rear passenger door was not closed all the way. Would this cause the battery to drain? Thx!
Post #244858 25th Feb 2014 6:39pm
possibly the FF didnt go completely to sleep because of the door being ajar..
Post #244863 25th Feb 2014 6:44pm
funnyguy1
United States
Thanks Stan, That is exactly what happened. Jump started it and is fine now. I have made a mental note to make sure all doors are completely closed when I shut it down. Mike
Post #244932 25th Feb 2014 11:57pm
Post #244943 26th Feb 2014 9:25am
Mike, the indicators only flash with the alarm set when all the doors are closed sir... Always look for the flash and you know all doors are closed Thumbs Up
You can check this theory by leaving one ajar and pressing the lock button, should lock but without alarm flash Thumbs Up
Another example of the D3 electronics being a better design, as they sound the horn upon locking if a door is not closed fully Rolling Eyes
Post #244946 26th Feb 2014 10:11am
Sandyt
The old p38 used to give a high pitched beep is a door wasn't shut properly odd how things are so called - improved Wink
Post #244952 26th Feb 2014 10:32am
exactly!
Post #244955 26th Feb 2014 10:41am
one reason why i've activated the lock/unlock chirp on mine with the iidtool, saves me looking at the indicators and i know its locked properly..
Post #244959 26th Feb 2014 10:52am
IIRC you can enable the horn/sounder bits in the CCF on the 2005=> models Smile
If a front door was ajar however you would hear it lock and then a split second later unlock as the lock mechanism bounces itself. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #245014 26th Feb 2014 4:25pm
