|  | Home > Technical (L322) > Dead battery this am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | possibly the FF didnt go completely to sleep because of the door being ajar.. | ||
|  25th Feb 2014 5:44pm |
| funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392    | Thanks Stan, That is exactly what happened. Jump started it and is fine now. I have made a mental note to make sure all doors are completely closed when I shut it down. Mike | ||
|  25th Feb 2014 10:57pm |
|  26th Feb 2014 8:25am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Mike, the indicators only flash with the alarm set when all the doors are closed sir... Always look for the flash and you know all doors are closed  | ||
|  26th Feb 2014 9:11am |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287      | The old p38 used to give a high pitched beep is a door wasn't shut properly odd how things are so called - improved  | ||
|  26th Feb 2014 9:32am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | exactly! | ||
|  26th Feb 2014 9:41am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | one reason why i've activated the lock/unlock chirp on mine with the iidtool, saves me looking at the indicators and i know its locked properly.. | ||
|  26th Feb 2014 9:52am |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | IIRC you can enable the horn/sounder bits in the CCF on the 2005=> models  | ||
|  26th Feb 2014 3:25pm |
| Posting Rules
