Home > Maintenance & Mods (L322) > rear arch lip. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
You need to put rubber protectors on the lip now.
17th May 2014 7:05am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
I got a plastic lip seal watching on ebay at the mo, but yes, will go the same if not carful
17th May 2014 8:07am |
That looks more like the stuff you put on the edge of the door to stop you banging it on the wall......
17th May 2014 9:28am |
I got mine from the local dealer, as they had them in stock and I was driving past.
17th May 2014 9:39am |
I've had the plastic strip as above fitted for 3 years now and still no corrosion on the rear wheel arches. I applied a thick coating of grease to both sides of the lip before fitting the strip and then wiped the excess off. I remove the strip each year and clean and re-apply the grease. Seems to work.
17th May 2014 9:41am |
Fine.........FINE.........you keep your plastic strips from a 1974 Mk3 Ford Cortina door edge and I shall take my "must be better as it says Land Rover on them" rubber strips and go and stand where someone loves me
17th May 2014 10:12am |
Who rattled your cage.
17th May 2014 11:33am |
Good. Glad we cleared that up.......
17th May 2014 11:38am |
now now children, its only its only a plastic strip ! If it dont work.......burn it!
17th May 2014 6:56pm |
He started it .
17th May 2014 9:57pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Stan will be smacking the back of somebody's legs 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
17th May 2014 10:29pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Metaphorically speaking I hope |
18th May 2014 1:11am |
