Home > Technical (L322) > Fault Indications, guidance please.
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
The following message centre reports come up after about 15-20 minutes driving:
'Air Suspension is inactive' and 'HDC inactive'
These are accompanied by the following lights coming on:
Emergency Brake Assist - on amber
Anti-lock Braking System - on amber
Dynamic Stability Control - on amber
The air suspension seems to be fine and working as normal. The car will remain at any setting for several day's if not used and seems to have no problem when on the move.
HDC, I haven't tested. But I find it odd that these 2 systems show faults at exactly the same time.
The brakes also seem to be fine and give me no concern.
DSC, again I haven't tested this (don't know how to)
But again I wonder why all these faults present themselves at exactly the same time.
I am wondering if they share any common connections, fuses or relays.
Can anyone shed any light on this please.
Post #262656 1st Jun 2014 8:42pm
Sounds like it could be an ABS sensor out or dodgy connection to one. Have a check of the wiring to the sensors for any splits or broken wires, and also that the plugs are ok.
That is the common denominator in all the faulty systems; abs, hdc, dsc etc all use the abs sensors as their point of reference. There is nothing that can't be fixed with a hammer😜😜
Post #262657 1st Jun 2014 8:46pm
mjdronfield
Is the speedo working ?
Is the steering really light at all speeds ?
+1 for the above. Pretty sure will be wheel speed sensor type issue. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #262663 1st Jun 2014 9:24pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Is your steering wheel aligned, ie not off-centre? I had a similar issue due to this. 2007 TDV8 Vogue SE Java Black
Post #262667 1st Jun 2014 9:29pm
iphs
Thanks for the replies fellas.
to answer your questions:
[i]Is the speedo working ?
Is the steering really light at all speeds ?[/
b]
Speedo is working fine.
The steering seems normal ie it is not to light making it skittish at speed.
[b]Is your steering wheel aligned, ie not off-centre?
Steering alignment seems fine.
I am also thinking sensor. I will have a good look around all the wheels and check the condition of any I can find (when I can get the time.
Post #262681 1st Jun 2014 10:38pm
ebajema
Did you have tyre and/or brakes done recently ?? Sometimes mechanics aren't that carefull and damage either a wheel speed sensor or ride height sensor.
Other problem could be the battery going. So worth doing a check on battery and generator. Just check voltage with the engine running and with the engine off.
Battery issues or better low voltage can generate a lot of false alarms. MY 2010 5.0 SC Galway green and sand interior!!
Post #262690 1st Jun 2014 11:51pm
stu1
Another possible is the yaw sensor (in the center console) - if this goes open circuit that's the symptoms you'll get - could be fine when it's cold but intermittent open circuit as it warms up.
If possible read the codes - there'll be something logged.
Post #262848 2nd Jun 2014 9:46pm
iphs
Thats interesting Stu1. Thumbs Up
Where, within the centre console would I find the yaw sensor. I am thinking that might be a good starting point.
Post #262854 2nd Jun 2014 10:34pm
stu1
If possible, get the codes read before it gets expensive replacing bits on a hunch/forum read Smile
As has been pointed out, other causes can be an ABS sensor (although you know your rear left is working as the speedo is working and the steering isn't getting either extremely heavy or extremely light at all speeds) or a misaligned steering wheel/column (steering angle implausible error) which can be caused by a poor tracking where the steering column isn't at 0 degrees rotation when the front wheels are straight ahead i.e. the system thinks you are continuously turning but the other inputs don't agree with this (in particular the yaw sensor), so you get an implausibility error which will cause various things to drop off line.
Anyway, the yaw sensor is inside the center console and sends an analogue signal to the ABS unit - if this goes awry you'll get the failures you're getting.
Sadly, I'm in Scotland otherwise I'd offer to come and read the codes for you - I suspect it'll pinpoint the problem pretty quickly.
Post #262855 2nd Jun 2014 10:46pm
As said, always get a code read before randomly replacing parts, it should pull up exactly which sensor is off line or faulty. Any good indy should do it for you at minimal cost. There is nothing that can't be fixed with a hammer😜😜
Post #262856 2nd Jun 2014 10:51pm
iphs
Cheers guys, I will get it to an indie and have that done as soon as I can drive again. Thumbs Up
As I only came across this yesterday, I haven't had time to do a google search for the faults being reported. However armed with the info you have supplied, it seems that this is exactly the problem I have. But as you say, I will get it checked out first.
Thanks again.
Post #262857 2nd Jun 2014 11:01pm
