![]() | Home > Technical (L322) > Fancy a Full Fat with a 2.0 4 cylinder diesel engine? |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Fair do's for them sticking with Camchain technology but IMO that camchain design is going to be a PITA maybe even in the short term as its more likely the chain will wear thru before the guides and just think of the metallic debris over the extended services thats going to occur...
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2628
I'd put money on it ending up in the Sport in some guise.
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
There must be a reason for it - maybe so it's easier doing different engine configurations with a modular approach? The thing is one reason almost all other engines take the drive for cams and ancilliaries from the front is the torque from the front cylinder has to be passed all the way down the crankshaft to the flywheel. Driving stuff off the front takes that strain off the crank.
Not for the diesel. That will have plenty of torque - they have to as they can't rev. |
What's a DP system? |
| fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 322
Dynamic Positioning - a system of thrusters and engine control that holds the ship to a position with fine tolerance, thanks to GPS position guidance. I don't have much experience, but I think +\- 50cm is possible. Not bad for an 8,000t ship... |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Hi all, I have had experiance of big 4x4's with 4pot engines, all I can say is the don't preform well under heavy load. In fact they normally explode! 6 or 8 cyclinders are better under stress ( towing 3.5 tons )
| campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729
Will reserve judgment until we see what the engine is actually like on the road. Just know that every other manufacturer has failed to get the refinement of a '6 or bigger... ML250 and ML350 are like chalk and cheese in this respect. |
| All times are GMT |
