![]() | Home > Technical (L322) > Super Charged gearbox woe |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Thanks guys for all your posts.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Part of the problem is that everything is inside the gearbox but I should have thought it would be possible to get them talking again. Hopefully someone with better knowledge will come along and help |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
@SO3isme. From personal experience, do NOT touch 3D Transmissions in Reading!! They completely bolloxed up the gearbox on our car when we purchased it - it had a leak on an oil seal and the dealer (non LR) had them recon the gearbox at his cost before we took the car. 4 months later it needed another recondition by TES Transmissions in Westbury and they said , quote " the gearbox looked as if it had been reconditioned by untrained chimps!! |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
"I am considering getting the dealer to take the car away and fix it."
Yes dingg1 - thanks for reinforcing your advice. I have e-mailed the dealer asking him to take the car away and repair it. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Shame you don't have an IID Tool .... When my battery was playing up I had gearbox and suspension faults - IID TOOL read lost communication with .... on lots of ecus - classic sign of battery issue apparently
It seems to me that correct diagnosis is 9/10 of the problem. |
Good luck with it all anyway SO3isme,
This is a slightly strange one. First I would suggest check battery and alternator. To make sure it's not voltage related.
Thanks for this useful sounding advice. Unfortunately, the situation requires a professional garage of some sort to provide the diagnosis, undertake the work and guarantee the result. As above, it really has to go back to supplying dealer to sort out and return fixed. |
Just let the dealer read the forum, they may save themselves money and time! MY 2010 5.0 SC Galway green and sand interior!!
'not a bad idea. You will note that I have yet to criticise. |
Greg66 Member Since: 11 Nov 2010 Location: London Posts: 84 ![]() ![]() |
When the ZF gearbox on our old Audi A8 died, I dug up these guys in Leatherhead, who were highly recommended (somewhere, can't recall where now): http://www.hardyengineering.co.uk
Thanks Greg, It's good to get a recommendation. The guy I saw this morning has a good reputation as a gearbox specialist. Unfortunately, he felt it was one for a Land Rover specialist! Somebody is wrong somewhere, but as in the above posts in this particular scenario I should not be the one having to do all this running about.
