![]() | Home > Technical (L322) > Brake pad wear indicator lead ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
this is from the 2006-2009 WM but it might give you an idea..[couldnt find anything in your year WM]
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Break pad wear indicator lead, clips into a groove on the pads, seems to have been left off.......
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Worn (warning light on) :
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
Thanks for the brilliant pics, shows exactly how they are fitted & work. Ordered new pads & lead
Exactly, wears to the contact, then light comes on. There is nothing that can't be fixed with a hammer😜😜
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
My 2003 TD6 has 2 wire sensors so I assume it is a closed circuit that once the sensor has worn becomes open circuit and maybe goes to earth as well though the disc. But mine has the rear one hanging loose and the light is on. All pads are ok and fluid is fine. Adrian VW Amarok 2014 Highline auto |
As today was such a lovely I thought sod it let's replace the rear brake pad west sensor after work.
