![]() | Home > Technical (L322) > 2010MY brakes (OR LACK OF) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35836 ![]() ![]() |
pretty sure mick [joker] mentioned that his s/c brakes were better than his non-brembo 2010 ones.. ... - .- -.
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
I have a 57 plate (MY08) model, my Brembo's look like this |
Bit baffled here, the performance is different yes, it can get up to a higher speed quicker, and may need to brake from a higher speed. However, and this is the nub, the vehicle weighs roughly the same as a TD6, and you are towing (at a max of 60mph). Performance does *not* come into this, the same 'not brembo' brakes will surely perform the same on both vehicles? Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
[quote="DMRR"]
That makes perfect send on a mecanical point of view, however, since drivers of TDV8 may be tempted to use more power and play more, hardier brake with more endurance are fitted. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
I would agree - but the main complaint here seems to regard towing..... Land Rover Addict
Oh and one more thing - if you turn on Forward Alert, the system will pump up your brakes, requiring less input from yourself if you are approaching something too quickly. Land Rover Addict
