Home > Technical (L322) > Pre heat
Page 2 of 4 <1234>
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Had a quick look on my phone which is difficult .......why the tears ?
Post #280950 14th Sep 2014 5:53pm
J evro
Paul do you have the PDF for the T90 as that's what mine is I believe?
Post #280951 14th Sep 2014 5:55pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
J evro..Tears cos its not working for you
I'm no expert, so not 100% that your remote is the right one as this is my remote>>
Link to T90 info >
http://dealers.webasto.com/Sections/Public...esult=true
Change product drop down to Telestart T90 (control units) and open the 2nd one down - english
Failing all this, do a car battery reset, fully charge it and go through procedure again.
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #280958 14th Sep 2014 6:33pm
J evro
Thanks Paul Thumbs Up
On reading the T90/80 PDF (which is what I appear to have) it says pull the 1A ( black fuse) fuse from the heaters fuse holder, anyone know what and where is the fuse they're talking about as it doesn't say that I can see ?
Post #281084 15th Sep 2014 12:07pm
paulmoran2
The Webasto Fuel Burning Heater T90 / T91 are used in many different makes / models, so the "fuse" is fitted on many, but is also a generic term for "pulling the power " to the receiver unit , which is something we can do on the FF by pulling the plug out .
The receiver should have a permanent power supply from the battery at all times, so check that with a multi meter as a first port of call as its easy.
If you have a copy of the workshop manual, page 2091 on wards may help with schematics.
If you do not have the workshop manual, I would recommend downloading it by downloading from this site (several dozen forum members have downloaded if from here without issues) its a big file so can take 30 mins to DL.
>> http://ul.to/po1djlav
Good luck
Post #281114 15th Sep 2014 2:29pm
J evro
Ok thanks, I just thought maybe this 1A fuse may have been the issue but couldn't see it inline, one thing I am not is electric minded so do I just get a meter and poke it down the plug holes with the 3 wires Embarassed ....to see if I've got a live feed ?
I would like to sort this issue but feel now it may be a visit to the dealer !
Post #281149 15th Sep 2014 5:09pm
Sandyt
Same remote as I have for mine albeit mine is a petrol (not the remote it has a battery ) Whistle
Post #281152 15th Sep 2014 5:15pm
J evro
Haha. Yeah might be less bother if it was petrol driven like a Zippo eh!
Post #281182 15th Sep 2014 6:33pm
paulmoran2
J evro...basically yes...Set your multi meter to 20v-dc and touch the black probe to a good chassis point, then touch the red probe on each of the three wires..one of them should show 12v.
You have already said that the heater works via the touchscreen, so that part of the system is working ok (including the 20amp fuse No 59 that protects the whole system) so your now looking at the either the receiver, loom / connection (to the FBH control module) or the fob itself / programming being the issue.
Sorry to not have any specifics, but you'll need to test connections, then look at swapping parts methinks Sad GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #281231 15th Sep 2014 7:27pm
J evro
Multimeter..multimeter indeed what the Censored would I be doing with such a high tech tool ....... I'm not a pro Stan Embarassed
Post #281374 16th Sep 2014 1:53pm
J evro
The strangest thing...
At about 3am this morning I noticed it was 15 degrees so as I was up and about I thought I would try the remote pre heat ( manual states it needs to be below 16 degrees to work) so I pressed the on button and low and behold ..... Nothing Censored ....so just in case I pressed the off button and everything sprung into action lights on dash flashing confirming it working / I opened the house window and could hear all the fans etc blowing away happily even seen the screen clearing, so pressed on button and it all shut down?.......now I wasn't going to go out to the vehicle at this time of the morning so just out of curiosity to see if I had pressed the off button and the system was still gearing up from my pressing the on button I pressed the on button and waited .. Nothing ..pressed the off button and away she went again all fans blazing , anyone heard of this before? .... I thought well as long as it works I can live with the reversed buttons Whistle , but today my mind is telling me to try and get this sorted ....any ideas folks?
And I've just bought a new remote fob Big Cry
Post #281900 19th Sep 2014 2:38pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
My 10MY has the T91 telestart unit, i followed this after changing the remote battery, worked a treat:
1. Insert the battery in the battery compartment of the transmitter.
2. Press the OFF button six times for 2 seconds at intervals of approx. 2 seconds.
3. Observe a waiting time of approx. two minutes.
taken from link above. i didnt need to kill the power to the unit to sych it. Cheers
James
Post #284122 2nd Oct 2014 7:45pm
J evro
paulmoran2 wrote:
J evro... Big Cry
Have a read of this PDF from Webasto>>
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
and / or PM me your mobile number, if you need to discuss.
Paul
Me again!.......it's 10degrees here so thought I would try my FBH this time I set it up on the touchscreen timer and system started up at the requested time but it turned back off after only 2 minutes? The heater unit under the battery in engine compartment on passenger side continued to whirr away for a further 2 minutes but at no time did any warm/hot air come out of the interior vents?,
Any ideas?
Post #284666 6th Oct 2014 7:07pm
JST
its either not getting fuel or not igniting the fuel it is getting Cheers
James
Post #284668 6th Oct 2014 7:13pm
J evro
Hmm no idea if/ when the previous owner used it last , is there a way to see if it is igniting ?
Post #284669 6th Oct 2014 7:18pm
Page 2 of 4 <1234>
