Home > Technical (L322) > Pre heat |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi j evro
2nd Sep 2014 10:54pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
It could also mean your battery is knackered, the one in the remote fob that is. May be worthwhile getting a new fob battery and doing the remote fob pairing sequence again. |
2nd Sep 2014 11:04pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Pairing sequence in case you need it>>
3rd Sep 2014 8:54am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 539 |
Excellent guys thanks will try above when I get back with the car
3rd Sep 2014 6:28pm |
Hmmm!
11th Sep 2014 4:25pm |
Unnecessary quote removed
13th Sep 2014 5:35pm |
The single is the antenna...try the triple wired connector..the receiver is permanently powered , so the key doesnt need to be in IIRC.
13th Sep 2014 5:52pm |
Cheers , tried to remove the 3 wire one but couldn't budge it ....how do they come off ? ....I don't want to snap it , I'm prone to that |
13th Sep 2014 6:25pm |
I'll have a look tomorrow and report back GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
13th Sep 2014 7:50pm |
Appreciated |
13th Sep 2014 8:38pm |
J evro...you just pull it off (there arn't any clips to push in or undo etc but it is very stiff ). If you remove the receiver from the back plate by removing the 2 black plastic hex nuts, then its easier as you can get a good grip of the plug (obviously not the wires) then simply pull / wiggle it straight out. Just done it just now with the ignition key not in.
14th Sep 2014 4:03pm |
Paul,
14th Sep 2014 4:09pm |
Okay... Removed the 3 wire 'plug' / followed sequence as above , renewed fob batteries, .... fob still flashing 8 times green for on and 8 times red when I press off...
14th Sep 2014 4:47pm |
J evro...
14th Sep 2014 5:18pm |
