Home > Technical (L322) > Pre heat
Page 3 of 4 <1234>
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i would test to see if its getting fuel first. they have an inline fuel pump which is usually located near the tank (i am talking on most installations i have seen or fitted to td5s or Pumas) not sure where it is on yours, you should here it ticking for the 2mins the pump starts to run. if you can hear it that shows pump is getting power, next i would check its getting fuel to the FBH by removing the feed pipe and checking for output.
Is there any smoke after the 2mins? Cheers
James
Post #284679 6th Oct 2014 7:33pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Ah I was sitting in the cab or at the front end so didn't listen for any ticking......there was no smoke at all ( I presume you mean from the burner under the battery?)
Post #284680 6th Oct 2014 7:42pm
J evro
I'm also informed by the chap at Webasto that my remote as per my previous photo is a T80? Not as I thought a T90/91....
Post #284681 6th Oct 2014 7:44pm
JST
yep, or its exhuast Cheers
James
Post #284693 6th Oct 2014 8:39pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
read this a few times to get your head round it
then start from the beginning
don't miss anything out
it may help you to get to the bottom of your FBH problem
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297
best of luck and keep us posted how you get on
nige
Post #284917 7th Oct 2014 9:46pm
J evro
Thanks for that, although it a bit above my head it's a great write up Thumbs Up
Think I need to book it in Whistle
Post #285075 8th Oct 2014 4:19pm
milesg
Guys I have read the brochure etc but....I got a new battery fitted to my remote, seems synced, press on and it goes green solid for 3 secs then flashes green every 2 secs, fan under the bonnet trim starts up, hit off and it turns off. T91 remote on a 2010 tdv8 car.
It is 9 degrees here so want heat (red light) not green. Tried the simultaneously pressing both buttons twice in a sec but no light appears to allow me to change it to 'heat' mode not ventilation.
Any ideas?!
Cheers Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather
Post #285148 8th Oct 2014 10:16pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
M...does the system operate correctly when using the touch screen rather than the remote? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #285177 9th Oct 2014 8:20am
milesg
Ill check this evening mate. Weird it will vent but not heat. I'll revert asap. Thanks again
Miles Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather
Post #285221 9th Oct 2014 12:32pm
J evro
A local LR dealer told me today that the FBH does not works unless temperature is below 6 degrees (not 16 as I believed) can anyone confirm this ?
Post #285300 9th Oct 2014 5:40pm
paulmoran2
Manual states below 16'c it will heat and above 16'c it will cool. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #285303 9th Oct 2014 5:52pm
JST
if you manually turn it on it will heat at current outside temps. Cheers
James
Post #285332 9th Oct 2014 7:46pm
It's a temperamental thing.....
Mine wasn't working and they replaced the whole unit. It would try to fire up but just cycle down after a couple of mins.
When you power it up can you hear a ticking noise from the pump, close to the rear of the car?
If it is a control problem have a search around because I think i remember seeing that it is possible to get the ecu repaired. There is nothing that can't be fixed with a hammer😜😜
Post #285363 9th Oct 2014 8:46pm
J evro
That's what I thought Paul.....but LR tech says 6'c ?
Post #285415 10th Oct 2014 2:13am
J evro
I can't hear any 'ticking' at all ?
Post #285417 10th Oct 2014 2:18am
Page 3 of 4 <1234>
