Home > Technical (L322) > Hi and "Help my brakes are not working"!! |
jfarrell32 Member Since: 23 Sep 2014 Location: Straffan Posts: 25 |
Hi, I have just joined the forum on the recommendation from a friend. I was on Landyzone for the past few years but this site was recommended as being more focused on the RR.
25th Sep 2014 3:11pm |
Time to do some research here but I have vague memories of the ABS unit needs to be purged by a diagnostic tool specific to a Range Rover , head for the search button and have a rummage.
25th Sep 2014 3:19pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Why the hell was he test driving it? |
25th Sep 2014 3:47pm |
Same reason he didn't bleed the air from the ABS block I guess , didn't know any better 2008 MY Supercharged
25th Sep 2014 4:02pm |
Thanks for suggestion. |
25th Sep 2014 4:43pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Hi John im only a stone throw from you in Celbridge .What garage do you have it with as may be able to suggest alternative if issue cant be sorted. Conor. Present :2008 TDV8 HSE
25th Sep 2014 5:31pm |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 |
i am in monkstown
25th Sep 2014 5:33pm |
It is RADS in clane. He has all the technology and does the service etc. for me, checked with him earlier and he confirmed he had bled block and was going to drain and start again! Will let u know! Strange!!! |
25th Sep 2014 7:00pm |
Thanks, will do |
25th Sep 2014 7:01pm |
am now told by the garage that it may be the master cylinder because he cannot find any air in the system. Says the seals may have been damaged when the system was empty and I was driving it (only for a few kms to garage after discovering problem). Does this sound likely? |
26th Sep 2014 11:24am |
Have a read of this
26th Sep 2014 4:26pm |
Thanks - will have a read. rgds john |
26th Sep 2014 11:17pm |
You drove it with a "split brake hose" really Do you guys not have recovery vehicles over there? I wouldn't even start the engine on a FF with a split brake hose... Let alone try driving it sir |
26th Sep 2014 11:26pm |
Great help thanks - I'll stick that in the "I told you so" bucket. |
27th Sep 2014 5:01am |
