![]() | Home > Technical (L322) > Britpart drilled/slotted disc's DA4609 have you got? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Hi all, I've just fitted some drilled and slotted disc's from Britpart, and I'm having some BIG PROBLEMS |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
I have them on mine but there is no significant vibration. Slight drone under moderate braking bu tunder hard braking the are good. Sounds like something else is out.
I know!!!!!!!!!!
Yes I did use new pads, and they are ecb, I've changed hundreds of discs in my time and never have I had this. I was just wondering if it was a drilled slotted thing. |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
Never had any problems in the past with that type of disc, although I have never used Britpart. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1861 ![]() ![]() |
Its a Britpart thing |
OK so I do have a set of wobbley discs |
Thats why they are known as S H 1 T P A R T |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
As Craig says absolute |
So what should I replace them with?? and dont say std. they wont take the punishment that I'll give them!! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Brembos....... There is nothing that can't be fixed with a hammer😜😜
I fitted Terrafirma drilled and grooved discs to my D3 (with Brembo calipers)
At least you got a few months use out of them, mine warped getting it off the drive |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i have drilled discs on front of mine fitted under previous owner. they run true and unnoticeable, except a very mild pedal vibration when motorway scare-dy-braking.
