![]() | Home > Technical (L322) > Slow to pull off if left a cpl weeks |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Hi, it might be the oil in your gearbox is draining into the sump during its long sit, it is just taking a short time to fill the system. I have noticed that if I try and pull away in a hurry from a cold start there is a delay before drive engages. But if I put it in gear and wait a few seconds all is good! maybe you need to slow down on the get away, I do |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
Thanks for the answer, that kinda makes sense, it certainly doesn't have any issues driving |
Thought that you were suppost tobe more laid back in France, with a slower pace of life, wot went wrong?? Yesterday I couldn't spell Engineer... Today I are one!
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Might be lack of fluid my p38 used to do this but only if slightly low on oil might be worth a check |
oops I'm back in Scotland, I change the flag when go over to the holiday house, which I am still doing a lot of renovation to. I shall immediately rectify my flag ![]() ![]() |
Cheers sandy i'll have a look, never hurts to be cautious |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Could be the old sticky gearbox cable, taking a few secs to get into the drive position.......
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
A full fat as get away car....don't turn it off while you're waiting in front of the bank |
Thanks |
![]() Although not to temp fate ... no I'm not saying it ![]() |
I would doubt it is low in fluid, unless you can see an obvious leak there is nowhere for the fluid to go. Be careful when checking the level it needs to be at the correct temperature to give the right level, if checked when cold it will appear low! There is nothing that can't be fixed with a hammer😜😜
There are definitely no leaks and it was serviced 5 months ago, full inspection service, pretty sure all fluid and oil checks were on the invoice too now that you mention it. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
Try lubing the cable. Can't hurt. There is nothing that can't be fixed with a hammer😜😜
Cheers i'll have a peek tomorrow, I might even look at my towbar ... then decide to leave it in the boiler room again |
