Home > Technical (L322) > Heater/climate settings when you first start car
nobbyclark
Ok, so I've had the car since last Friday and am really enjoying it. But one thing is irritating and I haven't worked out how to change it: when I switch on the car, the heater/climate settings default to A/C on, AUTO on and the blower on about medium. I want it to be whatever I left it at the last time I switched off, which is A/C off, AUTO off and blower on 2nd position directed at the windscreen. Is this possible?
Post #284809 7th Oct 2014 9:52am
milesg
Same problem here, any ideas FFRR'ers?! Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather
Post #285314 9th Oct 2014 6:45pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
IIRC, its a feature Sad GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #285315 9th Oct 2014 6:48pm
What car have you got nobby, please complete your profile Smile
My 02 behaves as you want, whatever setting I leave it on remains in place on restart. So if you are newer than an '05, maybe a downgrade (upgrade???) is needed.
The important one is to have Auto OFF. (Both the dot and the bar LEDs) .
Post #285376 9th Oct 2014 9:26pm
Robgosty
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Why auto off ?
Post #285402 9th Oct 2014 11:50pm
Quote from handbook:
Quote:
In Auto mode, airconditioning, air distribution, blower speeds and air circulation are adjusted automatically to achieve and then maintain the desired driving environment
I do question the word "desired" in the above, I guess this is based upon the temperature settings made that Auto mode works to. .
Post #285404 9th Oct 2014 11:59pm
RR2008HSE
Mine's an 2008. If I press the fan button, then it goes off auto. It doesn't reset to auto on restarting the car. If was on manual, it will stay manual. Some temperature changes will reset it to auto.
I'm really impressed with the hvac. I like the fact that, if I chose HOT on first startup with a cold engine, it will wait until there's some heat before starting the fan. I hate the blast of icy air I'd gotten in every previous car. Thumbs Up
Post #285418 10th Oct 2014 2:22am
nobbyclark
Mine's a 2010, will update profile soon.
When I switch the car on, Auto is ON, the light is on and the bar on the Auto button is on. I then adjust the fan or direction manually and it goes into manual i.e. lights on the Auto button go off. However, when I turn the car off, go and live my one life and return to the car, it is back in Auto mode again.
Will have another play with it at the weekend.
Post #285435 10th Oct 2014 9:08am
i'm sure the owners manual explains the procedures ...
but mine is as above , use as manual and next time you start its still on manual...never use auto. ... - .- -.
Post #285437 10th Oct 2014 9:11am
milesg
Nobby my 2010 does the same. A tad annoying. Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather
Post #285561 10th Oct 2014 9:10pm
I believe the logic behind this is that if a car has been parked up it starts kicking air out at an ok speed so as to get the cabin aired as it were. This helps clear windows and such like without much faff and the way i deal with it is as above, setting to manual Smile rarely does mine or has it been used in full auto other than long trips Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #285680 11th Oct 2014 10:18am
Discotigger
Is it not an additional memory feature of the keys, i.e. automatic reset on the memory seat, steering column, mirrors, etc., dependent on which key is used to open/unlock the FF.
If SWMBO uses her key to unlock the FF, it also changes the settings on the HVAC as well as the seat, etc.
If I tjen use my key to unlock the FF, all the settings revert to my key memory, including the HVAC controls.
Post #285750 11th Oct 2014 2:52pm
thats a thought , set the heating as you like it and then press the seat memory button.. ... - .- -.
Post #285758 11th Oct 2014 3:21pm
It could be an MY06 function for the heating though as the changeover to the newer integrated systems occurred then. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #285766 11th Oct 2014 3:32pm
nobbyclark
Will try that.
I did have some success with it remembering the settings at one point last Friday. But every time I've used the car since, it goes into Auto mode by default.
Post #286215 13th Oct 2014 9:56am
