![]() | Home > Technical (L322) > Solution to damp in ECU's - cheap and simple, for a change! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
you could also run the ac as that will dry out the air.. ... - .- -.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
You should run the A/C once a week to stop the seals drying out and cracking, if you don't use it you'll loose it, refrigerant gas, wot did you think I meant |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I thought the official advice was to keep the a/c running all the time to keep the vehicle dry. |
its not 'official' advice but it helps if you have a water ingress problem and as said its best to have it running every so often to lubricate the seals.. ... - .- -.
Certainly helps in winter to reduce condensation and clear the windows |
