![]() | Home > Technical (L322) > Fuel gauge indication wrong? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
In tank fuel sender/pump possibly, mine had a bit of an episode earlier in the year where it was inconsistent, the pump and the sender are in one unit for the 08my and possibly safe to assume that same for 2010->.
x-box Member Since: 18 May 2012 Location: uk Posts: 76 ![]() |
Many thanks, is it a common fault or not so common? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Sounds like you've lost a float off the sender in the tank Yesterday I couldn't spell Engineer... Today I are one!
Not a really common problem, but a few have had trouble with fuel readings. Bit of a pain to get out. Ordered a pump unit of lrdirect and got dealer to fit it. Saved a few hundred squids. Would investigate further before splashing out though as the units aren't cheap.! There is nothing that can't be fixed with a hammer😜😜
My car is still under warranty, will this be covered by? |
I would have thought so on the lr warranty, not really a wear and tear kinda problem.... There is nothing that can't be fixed with a hammer😜😜
Many thanks for your advice, will call dealer tomorrow |
Got the car from dealer last night, it's the connector's problem, they say they modified the wiring, it's fine now. Hope it remain fine.
