![]() | Home > Technical (L322) > headlight |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
could be the ballast but i would swop bulbs over first and see if it still happens.. ... - .- -.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Probably the bulb on its way out. As Stan (the man!) said, swap the bulbs over and that will confirm if it is the bulb that's dying. I had the same problem and it was the bulb, not the ballast (thankfully), that was going.
I have some used ones sir ![]() |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
I will swap them on the weekend and see what happens, I will let you know Craig
