Home > Off Topic > Non Land Rover crank pully bolt removal- advice needed
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I decided today that I was going to try and change the cambelt in my GF Hyundai Coupe. All was going well until I got to the crank pulley bolt. The instructions said, put your impact gun on the pulley bolt and crack it off or shock it off. Bloody thing will not budge, with impact gun and not sure what shock it off is.
Tried putting it in gear and put a breaker bar on it, brakes hard on and no luck, (think the clutch started to slip). Can't see any way to lock the crank and use the breaker bar.
So any suggestions on how to shift the fecking thing?
Just wondering if my compressor is up to it, I have an SIP 540nm impact gun, but it is running off an 8 bar Aldi compressor, do I need to upgrade my compressor? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #293227 15th Nov 2014 7:03pm
thinking outside the box here , but are you trying to undo the nut in the correct direction ? ... - .- -.
Post #293232 15th Nov 2014 7:23pm
Andy_J
yep, definitely turning it the right way as I have a new bolt to go in so can see it is standard thread 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #293235 15th Nov 2014 7:29pm
RiccartonRR
8 barg from your compressor is fine - your biggest worry my be the couplers / hose etc that won't allow the flow.
Check the CFM requirements of your impact wrench and then see if you system is up to it - you'll struggle to get the necessary cfm through one of those coiled hoses for instance.
"Shocking it off" means just that - hitting it with a sudden impact so the inertia of the engines internals don't allow the crank to rotate too much.
As Stan says, check the engine rotation and make sure you try and turn the bolt / nut in the same direction as the engine normally runs.
Using a breaker bar will not give you any shock unless you have a very trusting "mate" who'll hold weight against the bolt / nut while you give it the biggest whack (just lower than his hands) that you can possible give with a sledge hammer Rolling with laughter
Good luck - but remember, you have to be able to tighten it again (break out is typically 150% of tighten torque so should be a tad easier).
BTW, in the past when working on a particularly obstinate E30 (323i) I put a 2' breaker bar on the bolt and rested the handle on a block of wood before engaging the started motor Shocked Hugely entertaining and very very risky but did the job Very Happy
Post #293239 15th Nov 2014 7:38pm
Andy_J
Will check the CFM of the compressor as the impact gun always seems a little pathetic. maybe get some new hoses as I am using the ones supplied with the compressor.
Wasn't sure if the starter method actually worked or whether it was just an internet myth. maybe will try that (after checking engine rotation) 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #293248 15th Nov 2014 8:15pm
You want one of those sprung impact sockets.
My dad has one and it basically allows 1" of travel as you whack onto it but only has a left turning motion to get things off. You put the socket on it you need and while steadying it whack the end with a lump hammer.
Seems to do the trick most of the time and my theory is the shock and the twist is just enough to break the thread lock. Oh dont forget they prob put some locitite on that thing as well when new Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #293480 16th Nov 2014 3:17pm
