![]() | Home > In Car Electronics (L322) > Sat nav works on screen but no data on other buttons |
malkyo Member Since: 15 Dec 2014 Location: Pembrokeshire Posts: 7 ![]() ![]() ![]() |
Hi Dijit
Hi David,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
How have you isolated each device? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
have you done a 'proper' battery disconnection.. ... - .- -.
Hi Cam Tech Craig & Stan,
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 172 ![]() ![]() ![]() |
Mal,
Sounds very much like the BT module to me... They do like to throw up some really strange faults! |
I had bypassed it as it wasn't working and since bought a new one, I'm pretty sure it is not that bad boy, thanks |
Hi All,
Malkyo, were you present when the screen was swapped? Do you still have the old screen? I'm asking as I'd like to know how easy it is to remove the screen and secondly if it could be something as simple as a dry solder joint?
Hi Dijit,
ppcsl Member Since: 12 Sep 2012 Location: Ellon, Aberdeenshire Posts: 107 ![]() ![]() ![]() |
Hi, This is almost identical to what is happening to me except the radio is intermittent (still only on one station though). I was starting to think it was the radio tuning unit VUX500103. The system mainly didn't work through the summer when it was much warmer, well sun through the screen made the dash really hot. So it does make sense that it could be the head unit.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
BBA Reman do repairs on multifunction screens. Might be worth a go. |
Thanks for the info on BBA I will drop them an email and see if i can get some prices from them. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold. |
