Home > Technical (L322) > Rear Fog Lights |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I would suspect switch. Is one of the fog light buttons loose? This happened on mine as the rear fog light almost felt it was going to fall off. I bought a new switch but flogged car before fitting. Mine was intermittent. Present :2008 TDV8 HSE
19th Nov 2014 1:00am |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
switch feels fine in its mounting.
19th Nov 2014 7:25am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
water in the light unit?
19th Nov 2014 7:33am |
LCM? Cheers
19th Nov 2014 10:39pm |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 156 |
Light Control Module, the switches talk to it, it talks to the bcm can linked ect ect ect If everything is under control you are not going fast enough.
19th Nov 2014 10:42pm |
cheers, will do some more digging about Cheers
20th Nov 2014 9:33am |
it turns out to be the tow pack (after market fitted) disconnect the loom to the hitch connector and fog lights work as they should.
2nd Dec 2014 7:54pm |
