![]() | Home > Technical (L322) > LCM info needed please |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
The system seems to be over sensitive and at this time of year when the moisture starts getting to everything they seem to get upset, try removing and cleaning all the bulbs and holders, if the glass on any of the bulbs is starting to darken, then change them, just make sure everything is clean and new looking, the system is so sensitive it can pick up when a bulb is going to blow but hasn't yet...
Try a hard battery reset first... Although, early LCM's are getting problematic with age!
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Thanks Guys.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Unnecessary quote removed
Thank you Stetoe, that is good news. Made in Scotland frae 'Girders' |
Granted... Yes they are usable second hand... BUT!!! Will ONLY work correctly if that RR is from the exact model, year & marketplace as yours! They are programmed to the VIN of your car so second hand ones will almost certainly bring up strange faults sir... |
Thanks Craig.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
Worth looking at the wiring diagram for the lcm side of things as some light circuits are mechanical relay operated, and others have MOSFET transistors to power circuits.
