![]() | Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Seems like lots of places are making head units to fit now, curved, straight, Android, WinCE, the list goes on and on... they will all be pretty much the same to fit though...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
so whats the best option and make to buy please 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
Depends what you want it to do and how much you want to spend....
cheers for reply id like to spend around 1k in total any recommendations ? dab sounds good 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
cheers il have a look and get one just need a company to fit then 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
Check you have connected the correct wire in the boot to the can bus, there are several similar coloured wires, "Canbus to the green wire from unit,connect to the white/slate(grey)/yellow wire in pin 9 in the radio plug"
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
I've just ordered my kit
Says it in there somewhere, you need a 5mtr aerial extension lead... loads on ebay.... |
thanks pete, my kit turned up today, suprisingly quick as it came from Germany.
The sub output is on the green (ish) coloured phono plug.... there is no direct drive for the sub and it will require a stand alone amplifier to run it...... so that's one of your phono's used up |
There are a lot of wires going to the sub... easiest would be to follow them to the sub itself and see what's going on, it'l be down to two wires at the speakers themselves....!!!
