![]() | Home > Technical (L322) > Handbrake Lever |
Mal Member Since: 03 Feb 2015 Location: ne33 1lq Posts: 8 ![]() ![]() |
Morning folks,
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Wear thick leather gloves, there's lots of sharp metal in that area |
Cheers, will bear that in mind, but I was looking for a bit more technical advice |
Changing as I have been told by garage that the cable adjuster is not working correctly, I had the handbrake shoes adjusted and handbrake is still crap.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Before doing anything with the handbrake lever and cable have you had the rear drums off?
Yes all that was done and the shoes adjusted up, the handbrake works but not effectively and I don't think it would go through its MOT as is |
Unlucky.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Does that mean your cable is partly in the future |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
I replaced drum & shoes, adjusted, replaced cables. Still useless. Perhaps my adjustment mechanism on lever is knackered. Beware sharp edges and I look forward to hearing how you get on. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Have you tried it at different suspension heights? Due to the extreme articulation your handbrake can work well on off road height... Drop it to access height and your handbrake probably won’t hold the car at all! |
Have not tried that, but would have thought that the handbrake should work in all situations. No doubt I will have to replace the cables as well. |
There is a reason they changed to an elec handbrake sir |
Apparently that's worse most people I have spoken to reckon it always goes wrong and about a grand a pop to fix. Will stick to mechanical thank you sir |
