Home > Maintenance & Mods (L322) > Front brake pipes corroded
Page 2 of 3 <123>
On my '02 there was no intermediate connector for the FR pipe, just one long run from the flexi connection back to the ABS around the bulkhead. Guess for replacements they saw the error of their ways Wink .
Post #328687 19th May 2015 9:15pm
Zirconblue
It's like exhausts, they're one piece from the factory, but replacements come in bits.
Post #328697 19th May 2015 10:08pm
Mustard
Ive just replaced both my front brake lines due to MOT failure,
Buy them from Dan, they are cheap and they are factory parts ready for fitting Thumbs Up
Post #328876 21st May 2015 11:22am
Zirconblue
Are the factory parts pre-shaped? or just a straight piece?
Post #328884 21st May 2015 12:04pm
Mustard
pre shaped, same as what your replacing, no faffing about needed apart from the actual fitting Laughing
Just be sure to specify which ones you want.
Post #328886 21st May 2015 12:12pm
Zirconblue
Just a shame they don't do them in copper. Sad
In fact i think all manufacturers should be legally obliged to do them in a non-corrosive material, copper, stainless etc. Volvo used to do them in Copper from the factory!
Post #328889 21st May 2015 12:16pm
Mustard
inbuilt obsolescence Whistle
Post #328891 21st May 2015 12:18pm
Zirconblue
Exactly, yet they've all started building them with stainless exhausts.
Which is why they'd need to be compelled to fit decent brake pipes by law.
Post #328892 21st May 2015 12:19pm
Andy
That's a bit worrying. I hope mine has a join somewhere! The parts diagram shows them in two pieces.
Post #329313 24th May 2015 8:29pm
Andy
Just had a quick squint at the car. Can't see any join in the right hand pipe. Looks like I'll have to order the bulkhead pipe as well, along with the link to join the two together.
I've got the replacements from LR which are pre-shaped. however- they don't look the same as what's on the car. Granted I haven't took it apart yet but they seem to follow a different shape. Might involve a bit of twisting and bending here and there!
Post #329419 25th May 2015 9:19pm
Andy
Further update if anyone's still reading this
The pipes on the diagram are the wrong ones. The diagram is for a TDV8 and they are different. Turns out I need a full length one SGB000731 and SGB000741 are the correct part no's for a Td6
Post #329531 26th May 2015 9:47pm
That sounds fiddly! There is nothing that can't be fixed with a hammer😜😜
Post #329533 26th May 2015 9:50pm
Not saying I told you so, as there must be a way, but going bendy copper made fitting new pipes much much easier. Thumbs Up .
Post #329539 26th May 2015 10:34pm
Andy
I agree Joe. I wish I had gone down that route now.
I fitted the nearside one this morning and that was a bit of a pain. Managed to do it at full height with the wheel still on, but I had the same problem as you in that the pipe fitting was well and truly seized into the flexi. I just cut the whole thing off and fitted a new genuine LR flexi with clip. I had to straighten out the top of the steel pipe slightly to get it up through and behind the modulator. It helps to unbolt the modulator and move it to one side a little as it gives you a bit more room to manoeuvre. Bent it back into shape and it looks original again.
Wheel arches came out no problem but the smaller one snapped on its way back in
One side done. Tomorrow the fun starts with the offside!!
Post #329772 28th May 2015 12:41pm
Keep up the good work Thumbs Up .
Post #329811 28th May 2015 4:55pm
Page 2 of 3 <123>
