Home > Maintenance & Mods (L322) > Key fob stopped working
Brian
2004 TD6 - Just went to get into the car and the key fob I have been using since I bought it seems to be dead, no life at all - is this just a battery thing or possibly something else? I can use the spare key (thankfully I had it handy) but are there any gremlins waiting to pounce or is this a handy enough diy job?
Post #332458 14th Jun 2015 3:18pm
id start with the key fob battery first Thumbs Up ... - .- -.
Post #332460 14th Jun 2015 3:24pm
Zirconblue
It could be anything from just a flat battery to a wet, corroded or cracked circuit board. You wont know until you change the battery.
Post #332476 14th Jun 2015 5:45pm
Brian
I only asked as I saw a thread that mentioned a rechargeable battery so was not sure if it was this type of fob or a more modern one - But discovered when I opened the key (its a CR2016 battery BTW in case anyone wants to know) that the battery was very very slightly out of place Shocked a tiny press of my finger and it's working again - I suspect somebody may have knocked the key onto the ground from the shelf it was sitting on - so all is well that ends well but I'm going to order in a couple of those battery's as i don't have any in the house Cool
Post #332486 14th Jun 2015 7:22pm
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Is the CR2016 battery to "flat" for the battery holder? Is the CR2032 the preferred battery of choice?
I have a new key with a CR2016 and it seems to have gone flat very quickly as the key went inop inless than a month of getting it. Opened up and noticed there are a few pieces of paper between battery and key shell.
Post #333585 20th Jun 2015 3:47pm
Zirconblue
Handbook says CR2016
Post #333597 20th Jun 2015 5:03pm
georgedb
Thanks Zirconblue. will try another 2016 and see what happens
Post #333690 21st Jun 2015 3:48am
