![]() | Home > Maintenance & Mods (L322) > Had some damage due to road works, need advice |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Probably a good case for fitting rear mudflaps, the fronts obviously did their job. |
+1 for the diesel route |
Only just seen the mention of diesel, that will definitely dissolve it! |
Suggs Member Since: 16 Jul 2015 Location: Norfolk Posts: 94 ![]() ![]() ![]() |
wont damage the paint or plastic inner arches though will it |
Nope, but it will damage your skin if you don't wear rubber (PVC) gloves when you do it.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Think I'd get a small garden sprayer, you know the 99p things that you can also get WD40 in, and use that. You could probably wash most of it away using that method, I wouldn't recommend trying to rub it off as you'll probably spread it more, oh and put some news paper down to soak up the drips. Recon that a light mist and wait will soften it and a second squirt would shift it |
http://www.amazon.co.uk/Babymoov-Ultra-Abs...rbant+pads
You lot not herd of kitty litter? way cheaper and just the same as the granules they sell for oil leaks. I still think that giving the tarmac back to the road builders is the best way |
yep or sawdust also works well. But those absorbent pads will make the driveway a bit safer!
cheers
Actually thinking about this the best way to save the driveway is to just put the kitty litter tray under the area to be cleaned and go for it, but remove Tiddles from the tray before you start, otherwise you will have a moggy with the right hump |
i dont have a cat, should i buy one then in order to get a litter tray so i can put it on the drive |
No, I wouldn't go that far, maybe you could knock on a neighbours door and ask to borrow theirs' |
