Home > Maintenance & Mods (L322) > Underseal
crankcase
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Underseal
Hello all
My first time on here folks, so please be gentle. I have looked around on the search for this but cannot find specifics.
ME:
Had Rangeys back in the 90`s, Diesel Classic --- did a rebuild myself – then had the fantastic SL35 3.5 mazda put in over that god awful horrid 2.4 heap it had.... etc all good fun at the time.
Now back in the game with FFRR.
I did my homework prior, a lot of it on here, and a few friends who have FFRR. So I must thank all on here for sharing your incredible knowledge base. Without it I would undoubtedly have bought a dog !
I Looked at over 20 cars to find this....had almost lost hope), I’m fully aware of these cars idiosyncratic behaviour (though no expert) I am happy to deal with most basic spanner and fuse issues on it, but the comps leave me a bit ... well, WTF ?....
CAR:
FFRR 04 VOGUE DIESEL 63K, genuine mileage! , All original. No aftermarket bits or electrics added or removed (yet). Mint inside and out, Zero rust anywhere and I can eat my dinner off the engine bay. Was on a cherished plate been kept serviced, garaged its life and not used that much... Sadly, I don’t have an aircraft hanger of a garage to keep her in and will be using in the winter a fair bit so I want to protect the excellent condition.
ISSUE Under seal, before winter arrives
My question(s).
I’m in Bolton Bury area, Lancs. and looking for some solid advice on :
A... What is the best type of under body protection to get.
Then :
B... Can anyone advise of someone (in my area) who can do it (thoroughly and well) I don’t mind paying for a good service as long as it is thorough and good.
Any advice most gratefully accepted.
Regards
Phil Thumbs Up
Post #344740 27th Aug 2015 12:49pm
ebajema
Hi mate, welcome to the nut house. Cam Tech Craig may be able to help, I seem to remember that he does a fair bit of anti-rust treatment on his own FFRRs and I assume also for clients. He may be able to help you with this I hope. MY 2010 5.0 SC Galway green and sand interior!!
Post #344760 27th Aug 2015 2:06pm
Zirconblue
They're already under sealed from the factory, actually the majority of mass produced cars from the early 90's on have it.
What would be worth doing is an anti corrosion wax protection. In the body cavities as well as underneath. Have a look up "Dinitrol" they do a complete system for corrosion prevention. It's similar in principle to waxoyl but it's much easier to use, less messy and they have different products depending where you want to apply them to the vehicle. So runny stuff with good penetration properties for use inside cavities, and thicker stuff more resistant to wash off for use in wheel arches. The only problem with traditional under seal is if it splits water gets behind it and rots it's way out, wax doesn't have that issue.
Post #344763 27th Aug 2015 2:16pm
crankcase
Thank you gents
Looked up Cam Tech..... (certainly knows his RR) ...
Think hes in Gloucester, which is a hike from me at 4 hours or so.... but i will ask him about some advice on the subject, when I figure out how to do it Shocked
Ye,s I take your point about the factory treatment... Stiil think the old girl needs some help with the Northern salt though. Will also look up the Dinitrol. Thanks for the heads up Zircon.
Phil
Post #344834 28th Aug 2015 9:32am
crankcase
Thanks Zircon ...
This looks like the stuff ...
http://www.rejel.com/rejel-store/land-rover-kits/din01lr.aspx
Now ... how much is a four post car lift ? Laughing
Phil.
Post #344843 28th Aug 2015 10:56am
Zirconblue
Some drive on ramps and axle stands would do.
But yeah it's easier with a workshop ramp. I'm sure if you chatted to a decent local garage they'd do it for you.
Post #344845 28th Aug 2015 11:11am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
If you are on a tight time table / access problems - I suggest doing the following most urgently
1. Rear Wheel arches (remove liner and basically I slapped grease in there. Check out a thread by NiceDayForIt - he had some advice about this / replacement rubber protectors for the rim edge (Search forum)
2. Open Rear doors and check near bottom of rear wheel arch (area hidden when door is closed) - usually bubbling paintwork
3. Spray some (say acf50) inside boot lower tailgate cavity - particularly the seams - mine has slight bubble in one corner and I am hoping this stems it for time being (until I can get garage clear of junk and rehouse FF in there Smile
Hope this helps Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #344897 28th Aug 2015 4:12pm
The FF is far better built than the earlier Range Rovers (admittedly nowhere near as good as some German stuff though) because it is a monocoque it is made of much thicker metal as well...
I've had the carpets out of mine from front to back and there was no trace of rust anywhere inside on the floors, similar story on the underside of the floors...
As has been said, the wheel arches suffer, so do the front and rear subframes, the sills suffer where their not covered i.e. the jacking points...
I've sorted my sills and injected Dinotrol ML into the sills and other box sections but it's no where near as bad s earlier Rangies...
Not bad for 13 years old...
Plenty of holes when you remove the sill covers
It does get messy...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
-Click here for Thread-
Post #344919 28th Aug 2015 9:29pm
crankcase
Thanks Smutt
Ill get to that on the weekend... No idea how to remove the wheel arch liners, but I cant see it being rocket science Ill figure that...
I cant find that thread by NiceDayForIt Confused but then hes been a busy chap on here and has got pages of posts... Im struggling to plough through... Im sure newbies like me must p##s you guys off with numpty questions youve answered ad norsiam but it is not easy finding specifics in the threads.
Interesting stuff that ACF 50 corrosion block.
Again thank you for taking the time Smutt
best
Phil
Post #344920 28th Aug 2015 9:49pm
SMUTT
Hi - no problem - sorry for the short info on this I gave.
I can't find it now but here is a thread that might contain some nice photos and ideas.
http://www.fullfatrr.com/forum/topic7192-15.html
Basically you can get either official LR part for the rubber strip that goes over the wheel arch lip, but from memory it is a bit too short. Look on ebay you can get similar strip which I just packed with grease and slid it over the rim, wipe up the excess and hopefully it will keep the water out.
Search rear wheel arch should bring up plenty of ideas. Howard
Post #344949 29th Aug 2015 8:29am
SMUTT
mjdronfield has some nice pics here for you
http://www.fullfatrr.com/forum/topic9387.h...p;start=15 Howard
Post #344950 29th Aug 2015 8:30am
crankcase
Haylands, Smutt and all
Thank you for these posts this is both brilliant.... and very worrying !!
I have found, as Smutt warned i would ... the rust inside bottom of rear wheel arch ... at the (very badly designed) junction of the arch and side runner trim, which is little more than a salt and sh#t trap in my humble.....
Also, its showing corrosion on the inside of wheel arch on the metal edge with the rubber strips on (two of which are missing Evil or Very Mad ) ... attention needed there.
Haylands !
Did you lose a 50p coin in there ?
Man thats a full strip out, very thorough ..... I couldnt atempt that one under my current situation.
You must need a big space to store all that interior clean, dry and safe, then do the work......
An education there ...superb article, likewise the others linked up by Smutt....... I rebuilt my classic in another life but had A. time and B. a big farm shed to play in with no interuptions.. Sad
Im doing some serious head scratching now on this one ..... being very time poor, with only an open drive onto a busy rd and no cover..... with an impending winter.. Its no small job this .... requires space to put stuff and prepare stuff well... and good weather.
Im guessing finding someone to do this, as thoroughly as you guys do, is not easy.... And unless its done right its pointless.
Much food for thought and resarch there ....
Thank you again gentlemen .....
Phil
Owning these cars is like owning a grade 1 listed building...
but hey, it looks great from accross a big field on a sunny day Thumbs Up
Post #345126 30th Aug 2015 2:41pm
Strip out was from when it went swimming and couldn't hold it's breath... It was just to show how good a condition the floor was in after 13 years...
If you haven't got time to do anything else, buy a spray can of Dinotrol ML and spray it over the rust that is there already, it will help to halt it's progress until you can do it properly... you really do need to take the sill covers off,
I hope MrTee doesn't mind me using his pics..
Post #345136 30th Aug 2015 4:38pm
