![]() | Home > Technical (L405) > On the subject of weird noises.... |
| dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70
...well, mine is three weeks old (ATB TDV6) and, since the beginning, I've noted this Geiger Counter type noise that I've started investigating by changing various "configurations" in order to find out its origin and, for now, i think I may have found the culprit:
| modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237
Dfulgo...... Problem with auto lights (high beam) on 16my, LR are due to produce software fix.. |
| d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 442 |
- make front parking aid auto-activate as per menu and owners manual
@ modbarra: that's good news, thank you.
| Autobiography Member Since: 10 May 2011 Location: UK Posts: 926
I have full parking aid on my L494 and have the issue with the front sensors. LR know it's a software bug but they 'all do it' - yes they all do it wrong contrary to the manual!
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717
When i press P for 5 secs it says park aid unavailable please consult dealer, does that mean I don't have it ir its knackered? |
It means you've fully disabled PDC and AFAIK the dealer needs to re-enable it. 15MY introduced the new feature. 16MY changed how you enable the feature but 15MY doesn't forget your choice at ignition reset! |
| Ms. Mdx Member Since: 14 Feb 2015 Location: CA Posts: 62
dfulgo, does your ATB have the premium sound system with Conversation Assist (CA)? You might want to test that it isn't your CA that is picking up a rattle and broadcasting it over the speakers. You can turn CA off in the menu to test it out. 2015 RR ATB (Scotia Grey w/Cirrus-Ebony)
Thank you Ms. Mdx, but, I think no. I've checked it as soon as I read your precious previous posts on the matter and I found out that:
| Chaffers Member Since: 04 Feb 2015 Location: South Bucks Posts: 14
Mine has started making what can only be described as a farting sound, when you turn it off. Yesterday and today, about a minute after turning off the ignition, from the drivers side rear .. No change in ride height when it's sat there or anything like that, but just seeking opinions (and assurance!) thanks! |
| Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584
Chargers - it's probably to do with fuel tank, is it quite low on fuel?
Hi Nick, thanks for the reply. I've actually just filled it up what with Morrisons doing 102.9p, but I'd not even thought about the fuel tank. |
Bizarrely now I've un-tightened the fuel cap, which resulted in a vacuum type sound, it's stopped doing it, so I guess Nick you were on the money - thank you! |
