![]() | Home > Technical (L322) > Rear heater is cold? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi folks.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8762 ![]() ![]() ![]() |
You do know it has an adjuster for rear temp next to the outlet in the rear... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Don't know about pre facelift cars but mime has a button bottom right of the centre console which enables / disables the rear heater controls. If you have the light on then the rear controls are active, otherwise they match one of the two front controls. Which one I don't know/can't remember...
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
We experience the same on our 07 ffrr - mostly cold air in the rear air vents, regardless of how I set the rear temperature adjustemt knob. If I turn on the rear AC with the "real AC knob" on the front panel, the rear air is a bit less cold, but far from as hot as it is at the front.
Thanks folks.
IIRC its tied into the passnger heat setting as well so worth whacking that up and see if it makes a diff FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
not tried this myself but would the front center horizontal dial that controls the center/side vent temperature also control the overall heat to the rear center vents...
From the manual,
That's interesting.
Did you found out what caused the cold air in the rear vents? |
Unfortunately not. Still cold for passengers in the back. |
