![]() | Home > For Sale & Wanted > [SOLD] FREE OF CHARGE - Snow Chains for 255/50/20 |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
They are getting in my way now - and if I put them back in the shed they will stay there forever - so another week & they will go in the bin, which would be a shame.
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123
Will they fit 255/55/20, if so sold. letters not necessarily in the right order |
Comparison
| Matricks Member Since: 19 Jun 2015 Location: Wilts Posts: 17
Hi,
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
I have a set of these chains (LR accessory VUJ000020). The brochure says they are for 18" and 19" rear wheels only, not 255/50R20. The LR accessory for 20" wheels is the "snow traction system" LR005737 which is used on the front wheels. Looking at the 405 accessory brochure the snow traction system looks very similar, but has the part number VPLGW0081. Only Range Rovers since 1988 |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
I can't see a reason that a set of chains which fit the 255 55 19 or 255 60 18 won't fit the 255 50 20s as the rolling radius is the same. this means that the edge of the tyre is the same difference from the strut, and as the width of the tyre is the same then there shouldn't be much trouble fitting them.
They will fit just fine - on the 20's you might find that the chain is close to the rim - that's the only reason I can think of why the official kit is more of a studded belt type arrangement.
I agree that the sizes of the two systems should be the same, but as LR say 18 & 19 chains on rear wheels, 20 system on front, I would wonder whether there is something else to it. Miight the chain damage the rim of the 20" wheel as it needs a higher sidewall? And why the front/rear difference - might the chain catch something at the front?
Chains won't fit on the front at all - there isn't enough clearance - run your hand behind the tyre from 11 to 1 o'clock and you will see what I mean |
Now FOC |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
thats a bargain |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
P M sent. |
| Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800
There is a set of these on Ebay now item eBay Item No. 381485786977 at £329.99…listed for Discovery though? |
Will that include you delivering them to Somerset. |
| All times are GMT |
