Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
Greg,
10th Apr 2020 9:38am |
Talkwrench Member Since: 26 Nov 2019 Location: Lytham St Annes Posts: 17 |
Hi Greg, thanks for the reply. I’m still scratching my head to be honest. I’ve cleaned everything up again and put the undertray’s back on so I’ll see how I get on. Touch wood I’ve not seen any drips yet so hoping the oil I did see after the repairs was just the residual oil running off. I’ll be keeping an eye on it so I’ll update again if I find anything. But if anyone has some new ideas I’ll be happy to check it out. Cheers, Andy
10th Apr 2020 10:11am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Andy I'd whip off that under tray, it can collect oil, concealing leaks.
10th Apr 2020 10:37am |
mattjtaylor2809 Member Since: 24 Jun 2020 Location: Adelaide Posts: 1 |
Hello all, 1st time poster here.
24th Jun 2020 7:22am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Your engine bay is different in that the L322 has a cabin air intake above the back of the engine which once removed gives very good access to the back of the engine, unlike your vehicle where access is not so easy. Whether the oil cooler is replaced or split into its 2 parts and a new gasket is fitted is not affected by the above differences but when paying someone else to do the work you might be better off to have the cooler replaced purely based on the extra labour cost of cleaning the old cooler and with the guarantee that the cooler isn't split, although this appears to be a very rare event. |
24th Jun 2020 9:24am |
JRoth Member Since: 29 Jun 2020 Location: Stamford Posts: 1 |
I have a 2015 Vogue SE 4.4 SD and have just experienced the same symptoms. Is the fix the same as the older model there seems a lot more stuff to remove than described in the first very helpful post in this topic. Local non land rover outfit, Nene Overalnd is quoting £800 plus VAT for the repair! |
29th Jun 2020 6:33pm |
alfredlervaag Member Since: 18 Jun 2020 Location: krikane 5 6037 eidsnes Posts: 7 |
Hi ,is this the right size on the o-rings
12th Sep 2020 3:26pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
Cost me over a grand to get mine fixed.
12th Sep 2020 3:33pm |
Mariusses Member Since: 09 Nov 2020 Location: Berkshire Posts: 17 |
Hi there,
9th Nov 2020 7:18pm |
I attached some pictures to identify the area
9th Nov 2020 7:23pm |
I take it you have seen this in the Wiki?
9th Nov 2020 9:03pm |
Many thanks mjdronfield.Much appreciated.
9th Nov 2020 10:37pm |
The Wiki is top right in the header of the website. I remembered it being posted originally so had a bit of an advantage.
9th Nov 2020 10:55pm |
I am not sure if the baskets were not previously changed two years ago when I purchased the vehicle as I remember taking it back due to coolant leaking. The mechanic changed initially the thermostat but that did not solved the problem, after he mentioned that he changed the gasket on the oil cooler. Most probably only one of the gaskets. I might order both and get them replaced for my peace of mind.
9th Nov 2020 11:23pm |
