![]() | Home > Technical (L322) > Limp mode help please !!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
Sounds like an abs sensor or a height sensor, get the faults read and all will be revealed.... Pete
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 ![]() ![]() ![]() |
Abs sensor, that could be a thought as the dealer that sold it to me had just had new discs and pads all round the day before he dropped it off to me.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
did you set the steering parameters when you fitted the new battery?....[how to in the wiki].. ... - .- -.
Hi Stan, I am not sure as the dealer did it when I asked him to look at the faults.
can do...leave it disconnected for a few hours then reconnect and turn the steering wheel fully left and then fully right.. ... - .- -.
Stan, will I need to enter a radio code or any thing like that or just disconnect both sides and reconnect a few hrs later.
no code needed... ... - .- -.
Make sure you follow the correct battery disconnect procedure, not doing so can be expensive and dangerous...
Thank you both I will try it tomorrow. Thing is because the fault is very intermittent you can't tell if it's fixed.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16391 ![]() ![]() ![]() |
Where in Brizzle are you Dave? |
Oh yeah, didn't notice you were down that way, pop in and see Craig, he's a top bloke who can sort it for you.... |
Hi Craig. Live in nailsea but work bs2.
Quick update, took the car to a local Indy today, he rang me and said the code was pointing to low fuel pressure. He said take it away and use it for a while, he would give me a ring when he has time to look into it more.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
11.5v is discharged and will affect a L322 tdv8.
