Home > Maintenance & Mods (L322) > TDV8 EGR maintenance
austeve01
Australia 2008 Range Rover Vogue TDV8 Santorini Black
Hi. Can anyone tell me how difficult it is to clean the EGR's on a TDV8 and whether it's an expensive job or not ... or perhaps it's better to replace them?
Thanks
Steve
Post #373258 20th Feb 2016 12:55pm
Mikey
Once you have gone to the extent of removing them, you will probably decide to replace them anyway.
Not a job you want to be doing twice Laughing
Post #373260 20th Feb 2016 1:10pm
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
Better to replace. Here's a how to I wrote earlier. Thumbs Up
http://www.fullfatrr.com/forum/topic32601.html Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #373269 20th Feb 2016 3:05pm
austeve01
Thanks Mikey. Appreciate your candour.
Post #373363 21st Feb 2016 10:46am
austeve01
Thanks for your advice Edfors. Looks like replacement will be the go.
Cheers
Post #373365 21st Feb 2016 10:55am
rar110
Gday Steve
Are you having some EGR problems? ______________________________
Post #373487 21st Feb 2016 10:06pm
austeve01
Hi Pete
Not sure. Going to get M R's opinion next service which is shortly. No indication from the dashboard that there's a problem but it tends to blow a bit of black smoke if I plant my foot (which I might add isn't often). I can't remember that happening under the same circumstance with the D3. I've nearly done 145k and the EGR's have never been replaced. Otherwise the car's a dream!
Cheers
Steve
Post #373545 22nd Feb 2016 11:28am
rar110
Gday Steve
Mine will give a bit of black smoke with a boot full. I was also previously concerned about black smoke and had the mechanic put through some induction/EGR cleaner. It improved after the treatment. Mine has nearly 250,000km and the original EGRs going by the service history from about 90,000km. Yep very happy with the tdv8.
Pete ______________________________
Post #373558 22nd Feb 2016 12:57pm
33sport
2007 Range Rover Vogue TDV8 Stornoway Grey
worth checking your hoses for splits, I had a crack in the offside plastic rocker cover which made the engine smoke, had it changed which was an expensive job, but now is perfect no smoke.
I also had the egrs replaced at the sametime.
Post #373585 22nd Feb 2016 5:26pm
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
I'm sure some smoke is normal, most diesels do, it seems the key is to clean it out from time to time otherwise it builds up and blows out all the build up in the exhaust when you put your foot down to overtake on the freeway. I've notice in the country; put your boot into it and clean it out and it stays clean for a while. Anything to do with fitting dpfs to the later? Also the Intercooler hoses are crap, I've had new ones last only a year, you may think they are ok but they are not. Fit silicon hoses. I had to take the manifold off and fitted new hoses when refitted and I noticed the improvement straight away but I didn't seem to have any leaks prior, pitty can't get silicon hoses for the 4 short pipes on top.
Post #373843 24th Feb 2016 9:02am
Hammer
I'm interested in the answer to the question as well, can they be cleaned? And if so will they be restored back to normal operation?
Cheers Paul
Post #374025 24th Feb 2016 10:26pm
proser
To be totally honest there is no need to clean them as they do not get blocked up like on other cars. I have a couple of EGRs in the garage and they have a light coating soot but nothing like I have seen on other vehicles.
If you are going to remove/replace then you can get the inlet manifold off with out having to disconnect the wiring to the injectors. you just need to move the manifold to the left (looking into engine bay) and then swing the right side out and then move it right and lift off.
For my first time, I was removing EGRs in and hour from starting. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #374032 24th Feb 2016 11:19pm
austeve01
Thanks. I did replace the 2 top turbo hoses recently due to splits .. the 2nd one within three weeks of the first one. Improvement in performance was noticeable and of course no black smoke
Post #374033 24th Feb 2016 11:28pm
austeve01
I'll give this a try. I agree with you re the intercooler hoses. Unfortunately for me on both occasions I was out in the sticks and local garages could only source parts from capital cities with a wait of up to two days! Phoned my workshop & they despatched genuine to me straight away. I have not found anyone local who stocks silicon which I would prefer.
Post #374034 24th Feb 2016 11:36pm
austeve01
Thanks for that info. I'm impressed with removal of those EGRS in that time.
Post #374036 24th Feb 2016 11:40pm
