Home > Technical (L322) > Faults from IID Tool
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi Guys, If you could point me in the right direction of where is best to find out more about these and if any are serious that would be great!
Vehicle scanned on 08-06-2016 11:19
Using IIDTool BT V3.0 B2193
AAM-Audio Amplifier
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( on 05-04-2016 17:45:03 at 138067 km )
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
ACM-Audio System
U0159-00 (2A) Lost communication with parking assist control module
( on 08-06-2016 11:19:09 at 142736 km )
DCSM - Drivers Clim Seat
U0140-00 (2Cool Lost communication with body control module
( on 05-04-2016 18:38:55 at 138103 km )
HVAC-Ventilation
B102E-11 (6C) Air quality sensor - General electrical failure - circuit short to ground
( on 07-06-2016 19:43:13 at 142735 km )
IPC-Instrument Pack
B1A85-96 (6Cool Ambient light sensor circuit - Component failure - internal failure
( on 09-05-2016 18:16:41 at 141058 km )
U0128-00 (2Cool Lost communication with parking brake control module
( on 07-04-2016 10:55:30 at 138124 km )
KVM-Keyless
B1335-00 (6Cool Front triangulation/loadspace antenna
RCM-Airbag
U0121-00 (2Cool Lost communication with ABS control module
( on 29-05-2016 10:41:04 at 142397 km )
U0415-00 (2Cool Invalid data received from ABS control module
Post #390719 8th Jun 2016 11:24am
if thats your first scan then clear the faults and check in a weeks time.....its possible that some are historical...
or if you really need to know what the codes mean then search the code on the forum or go to the code link in the wiki or have a google.. Wink ... - .- -.
Post #390727 8th Jun 2016 11:45am
Mcnallykev
Thanks Stan. Not my first scan I'm afraid Sad I will have a look at the Wiki
Post #390729 8th Jun 2016 11:49am
ah, ok..i get regular faults come up like the speaker one and a tmc one but it all works ok.. ... - .- -.
Post #390730 8th Jun 2016 11:55am
Davidmudley
Re: Faults from IID Tool
HVAC-Ventilation
Did you ever get to the bottom of these errors? I have the same and am struggling to find the air quality sensor replacement part (or number). I haven't started on the speaker circuit issue yet.
Thanks. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #636808 13th Jul 2022 12:33pm
Mcnallykev
Hi David.
I didn’t I’m afraid. Sold the car as it was the biggest money pit I ever had. 😂😂
Good luck.
Post #636814 13th Jul 2022 1:09pm
JayGee
HVAC-Ventilation
Thanks.
I have these and believe they are not real faults but spurious glitches. The air quality sensor is a BMW part AFAIK and easy to replace if you need the recirculating AC feature ( if it is even faulty ) 2012 TDV8 Vogue (L322)
Post #636816 13th Jul 2022 1:38pm
Davidmudley
I think I can live with the errors, but I went to have the air con checked today and they could t get it running cold despite it being gassed up and suggested there may be an issue somewhere that an error code might be able to pin point. Hence thinking it might in some way be affecting the air con circuit from getting properly cold.
The other stuff I’m less fussed with but I do think there is a slight drain on my battery as I regularly get the low battery warning light, though it’s never become any worse than that (always starts). Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #636818 13th Jul 2022 1:53pm
JayGee
The sensor only works when the AC recirculating feature is used and has no effect on the normal AC operation. If you have no cooling after a regas it’s likely the compressor is the fault (RCV valve / common issue). There is a recent thread explaining DIY replacement if you are up to it. 2012 TDV8 Vogue (L322)
Post #636820 13th Jul 2022 1:58pm
Davidmudley
Thanks JayGee, I'll get investigating further. Out of interest would you expect the compressor to spit out an error code of some sort? Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #636823 13th Jul 2022 2:12pm
JayGee
https://www.fullfatrr.com/forum/topic63831.html
https://www.fullfatrr.com/forum/topic63889.html 2012 TDV8 Vogue (L322)
Post #636824 13th Jul 2022 2:17pm
Davidmudley
Thumbs Up Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #636825 13th Jul 2022 2:19pm
DrRob
Does sound like a new compressor job to me. I had same. Full gassed, no leaks. New compressor, job done Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #636835 13th Jul 2022 4:42pm
DrRob
Who looked at this for you? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #636836 13th Jul 2022 4:43pm
Davidmudley
ATS Euromaster, so not who I would consider experts in diagnosis. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #636839 13th Jul 2022 7:33pm
