![]() | Home > Technical (L322) > Aircon - off and on.... |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
you should have your Aircon on most of the time as it keeps the seals moist and sound. it also removes water vapour from the air inside. (A/c can also be used for heating)
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 548
I understand over-filling can cause those symptoms. That said, I once had a 5 series that did it and could never get to the bottom of it. 2016 Skoda Octavia VRS Estate
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
It's always on (Auto). Never had to deal with this amount of heat before so only noticed the cooling not working continually. 2012 TDV8 Vogue (L322) |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
First thing to do with any aircon issues, is to recover the refrigerant and compare to the specified charge weight. 10-15% under is acceptable for a system not recharged within 2-3 years and rarely used.
Also if I set the temp to minimum the air from the vents is not 'that' cold. Maybe I'll try a regas and take it from there. 2012 TDV8 Vogue (L322) |
If it needs a recharge and it's been in regular use, then there's a leak. It's illegal to recharge a known leaking system, whoever does it can be liable for a fine of up to £5k and lose their F-Gas certification - Enforcement is another thing however....
I'd presume a reputable garage would pressure test the system? 2012 TDV8 Vogue (L322) |
Always check, never assume |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Sounds like the well-known RCV/PCV issue on your air con compressor. I get exactly the same symptoms and was something i got money off for when i bought the car (my hope was that cleaning the cabin temperature sensor and fan or an air con recharge would solve the issue cheaply). A good test to confirm is to leave the vehicle in park and rev over 2,000rpm (when you have the air con switched on but no cold air is coming through). If the air con starts working (could take 30 seconds or so), it's 100% an issue with the compressor (RCV or clutch - either of which mean a compressor replacement). I'm no HVAC expert but I think it's being hopeful (and wasting money) to think a recharge will solve the issue. If the vehicle is capable of providing ice cool air, you've got plenty of refrigerant in the system and no leak, as otherwise the system would be incapable of providing cool air, with insufficient or no refrigerant to exchange. Maltings Offroad have got them for £280 at the moment. I've just ordered one. I'm planning on doing the job myself - a quote from a reputable garage was £460 for the compressor PLUS air con recharge PLUS £600 labour! Total bill was £1,100. My costs will be £280 for the part plus £80 for a local garage to pressure test and vacuum before I do the job and refill once the job is done. Also crucially, as others have pointed out, leave your air con on all year. It will prolong the life of the system/components. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 22nd Jun 2022 8:26pm. Edited 1 time in total |
From my post earlier - it's not capable of providing ice cold air at any time. It's at best 'chilled' 2012 TDV8 Vogue (L322) |
"When it was cooling it almost felt too cold like a very old AC system that just has an on and off switch"
Christ - you're good - if only I had your insight and balls of crystal not gristle, I could have forgone all those years of training and experience, being able to definitively diagnose over the interwebs is a skill indeed, I take my virtual hat off to you. |
Not going there. If you're bored and looking for an argument, please go elsewhere.
See my first post which mentions 'refrigerant control valve'. It may surprise you to know that people have knowledge which extends beyond their own vehicles...
| All times are GMT |
