Home > Maintenance & Mods (L322) > 4.4TDV8 advice
Page 2 of 3 <123>
Yes check for "oil drain pipe modification" is a 10 hour modification requiring drilling the block at owners cost...
Post #391473 13th Jun 2016 7:26am
rr driver
United Kingdom 2011 Range Rover Autobiography 5.0 V8 Santorini Black
Wow, back to school with a thesis to read.
Need to digest can then ask questions.
Unnecessary quote removed 2011 5.0SC Santorini Black
2009 5.0SC Santorti Black - Been stolen.
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #391503 13th Jun 2016 12:26pm
rr driver
Is this something that they will do or should do?
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #391504 13th Jun 2016 12:34pm
this mod is only done if the FF needs it, it will not be done 'just in case'
on your test drive , floor the accelerator so that the revs go over 2500 rpm, if smoke comes out of the back then you need the mod, if not then you are ok...
if you get an LR approved FF and if the mod has not been done then you have two years to find out whether you need it ...
edited for spilling masticks... ... - .- -.
Post #391505 13th Jun 2016 12:43pm
So it's quite good then? Rolling with laughter Got - 2017 SDV8 Autobiography in Loire Blue
Post #391507 13th Jun 2016 12:58pm
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Well @ rr driver...you did ask Wink
There is a little marketing hype in there, but most of it is good engineering strategy and solid information.
As an automotive engineer I like to make informed decisions Smile 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #391512 13th Jun 2016 1:43pm
rr driver
Yes, so just a little good then!
I am only looking at LR approved as i know the warranty is worth it. 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #391514 13th Jun 2016 2:45pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Hi all, hope you don't mind me resurrecting this! I'm in the process of looking for a 4.4 at the moment. Has anyone got any idea how much this mod would cost if I required it? And what is the easiest way to identify weather it has been done or not?
Thanks in advance for any help and advice. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #433374 31st Mar 2017 7:12pm
it will cost around £1k..
secondary turbo drain valve modification tsb here,
http://www.fullfatrr.com/gallery/albums/us...Smke~0.pdf ... - .- -.
Post #433376 31st Mar 2017 7:32pm
stu
Shocked
Thanks for the reply Stan. Is it necessary if no smoke? Or best to have it done regardless? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #433377 31st Mar 2017 7:41pm
because the 4.4 tdv8 is such a lazy engine most dont go over 2500 rpm when at those revs the second turbo kicks in...if and when you test drive , boot it so the revs go over that rpm and have a look in the rear view mirror for excess smoke.. ... - .- -.
Post #433379 31st Mar 2017 7:51pm
stu
Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #433388 31st Mar 2017 8:55pm
Baltic Blue
I had the turbo drain mod done in January.
The car is a dream to drive now. As Stan says , I rarely thrash it to get it anywhere near 2500rpm, whereas previously I was constantly thinking, I need to get the revs up to burn off the oil.
I have "tested " it several times, but not seen a hint of smoke since the mod and now just enjoy the power when I need it.
If you are buying from a MD, I would insist that it is done before parting with your cash. It wasn't easy to convince LR to pay for it.
Enjoy,
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #433427 1st Apr 2017 8:37am
stu
Hi Mike, thanks for the reply. The car I am looking at buying, I took it for a drive today. There was nothing at tick over, I got the guy to rev it hard whilst I was stood behind and nothing either. I spank it a couple of times on the test drive and still nothing! I am hoping it is ok.
How did you get the dealer to pay for it? The one I am looking at is from November 2011 and falls in the chassis number bracket on the sheet I was sent by Stan. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #433465 1st Apr 2017 3:11pm
If it's not smoking then I would be inclined not to worry about it too much.
I've not had it done on mine and not had any issues, only once got smoke after it had been started and moved at the garage a few times this builds up the oil in the secondary turbo which then gets smoky when it kicks in. Unless it's displaying problems and you have the LR warranty then you will struggle to get them to pay for it. The tsb details what has to be done and it involves drills and holes in the engine block! There is nothing that can't be fixed with a hammer😜😜
Post #433470 1st Apr 2017 3:21pm
Page 2 of 3 <123>
