Home > Technical (L322) > drivers door key not opening door
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
hi anyone know how to fix drivers door lock key will not work at all after flat battery problems dont want caught out again also should key work lock mechanically ?
Post #397852 26th Jul 2016 10:16pm
mr_spock
Can you feel any resistance to the key turning or is it quite loose? Could be the extension on the lock barrel broken or just come out of the receiver.
Post #397861 26th Jul 2016 11:35pm
DO NOT TAKE THE DOOR CARD OFF, do not touch the door card, there is no need to remove it, only remove the outer handle and lock and reset the cam to the central position.
Open the door and look at the back, there is a grommet, remove this and it gives access to a torx bolt, remove the Torx bolt and the handle comes off. The lock assembly then lifts out and you have to realign the part that's left inside the door. Just use a screwdriver to do this and reassemble.
When you look inside you will see a slot similar to the either image 1. 2. or 3 below, the slot could be in various positions depending on how it popped
Using a straight blade screwdriver gently reposition the slot until it is like the image below
Carefully refit the handle, Torx bolt and grommet and test to ensure it is working
Post #397882 27th Jul 2016 8:20am
good advice from John ^ Thumbs Up
this info is also in our wiki [with pics]
http://www.fullfatrr.com/forum/post328029.html#328029 ... - .- -.
Post #397883 27th Jul 2016 8:25am
rik
thanks for that will try asap
Post #397965 27th Jul 2016 7:09pm
rik
ok took bolt out lock wont budge there are 2 bolts holding it in. first bolt dropped into door . card. off. with the help of a magnet got it back. can not see slotted screw anywhere mabe my door is different ? removed door lock lower screw left hand thread upper screw right hand .put it all back together and wala the bloody thing is working dont know what i did sprayed everything with silicon while i was in there i will have to disconnect battery to find out if lock is working mechanically some pics of lock
Post #397985 27th Jul 2016 11:12pm
rik
Thinking about this/ lower screw probably dont need to come out/ as there are 2 grommets i mistook this one for lock removal one hence the mystery. however i still dont know why it is working now or why it would stop working in the first place .any clues ?
Post #397996 28th Jul 2016 8:48am
