![]() | Home > My Range Rover > My Remapped 2002 Range Rover Vogue 4.4 V8 |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 930 ![]() ![]() ![]() |
Finally got rid of the horrible tatty bonnet pannel as the one I painted star silver 4 was ready.
I have just bought a set of 20" wheels that I like, one needs welding and they all need tyres. Can't wait to get them fitted. This means the current wheels will be transferred over to my Autobiography. |
I finally got around to replacing the damaged and bodged air intake pipe. £17.95 with free p&p. Very happy.
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
There is a gasket in that photo you posted but they have also used gasket sealer on it.. which they should use in certain places.
Cheers for the above info. Sadly the sealant is all the way round where the rocker cover meets the engine, not just patches |
Managed to make some good progress on the engine cover. But other jobs got in the way so was not able to get any further today.
20" Wheels collected. A lot scruffier than I thought, but happy with the purchase all the same. Can't wait to get these on. Sadly that will be a few months |
I managed to get the white on the engine cover. Just have to wait a week or until the weather is dry again for the paint to cure properly before I can prep the black I already painted for either 1 more coat, or hopefully lacquer. Then need to work out how to paint the logo and lines silver again.
I have added a bit of bling to my Range Rover today. I used my original Christmas presents from 2 Christmas's ago on the TD6 and replaced them quickly, so now have the chrome effect door handle covers on both my Range Rovers which effectively covers up the original tatty handles |
The thermostat has behaved itself since it one off hissy fit. I still have a very slow coolant leak, no idea where from.
I took the powerfulUK grill off today and fitted the Kahn grill. Only thing needs to be done now is to take the Autobiography badge off of the grill that the was already on it when I bought it. This grill looked |
Decided to tackle a job I have been putting off for well over a year. The headlight ballast. Turns out, the one I bought was not the right one, and a headlight I had bought which had one on it that apparently worked, doesn't at all. So had to put the car back together. I was going to replace the switch and reg lights in the tailgate, but ran out of time as I got side tracked when my mechanic turned up to sort the handbrake out on the other Range Rover.
Don't know what got into me yesterday, but I found loads of motivation until the rain started.
My Vogue now has the horrible 5 spoke Autobiography 18" wheels on it. This is only until I can get the money together to get the 20" 5 spoke wheels refurbished and tyres fitted. The car looks awful now.
