Home > My Range Rover > My Remapped 2002 Range Rover Vogue 4.4 V8 |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 920 |
Chuffed to bits. It sailed through its MOT with no advisories today.
7th Mar 2019 8:20pm |
Now added the tuning companies stickers to my custom engine cover.
8th Mar 2019 5:10pm |
Engine cover now back where it belongs.
10th Mar 2019 2:37am |
Another job crossed off the list. Mankey old pollen filter replaced with nice new one.
17th Mar 2019 3:31pm |
Finally got round to wiring up my app controlled WiFi Reverse Camera. Ended up moving it from the upper tailgate handle, and placing it under the rear bumper. Only down side is, it takes 10-20 seconds for the camera to connect to the phone app, and if you happen to be near your home and have your home wifi set to automatically connect to your phone, then you have to manually change the wifi back to connecting to the camera. But the picture is crystal clear. Very happy with it.
30th Mar 2019 8:34pm |
I got bored, decided to attempt to make my splitters look similar to the Overfinch kit. Hope it looks ok on the car.
10th Apr 2019 11:05pm |
Got the trims back on, happy with how it is going to look, but not how it is now, luckily I took Tank up to Surrey to collect new trims with fully in tact tabs. As these ones lasted all of 2 seconds back on the car due to broken tabs. So tomorrow I have to go and buy a specific sized (60mm) holesaw, to cut holes in the new trim. Also discovered that my fuel tank heat shield has completely detached from the car now But had massive fun this afternoon driving through Eynsford Ford 4 times
19th Apr 2019 8:53pm |
Picture of the holes I cut in the splitters.
22nd Apr 2019 9:50pm |
The look is starting to come together. I am not happy with the one hole, so going to add 1 more.
23rd Apr 2019 6:28pm |
Finally finished the mod I started. I am now happy with the final decision. Now waiting for the glue to dry, then the splitters can be fitted back on the car.
26th Apr 2019 4:05pm |
Think I managed to get a better picture of the modified splitters. Not had time to clean the car though.
28th Apr 2019 4:43pm |
Between hospital visits, resting and bad weather, all I have managed to do was sand down the corroded spare window trim and use filler on it. I have smoothed it right down since the picture was taken though. Depending on how I feel Friday, I plan on fitting the vinyl wrap to the trims. I have been banished to the outdoors for that part though as the adhesion promotor stinks so my partner kindly put our gazebo up with the side panels on ready. After all this effort and expense, I hope it looks good. I have spent in total, about £50 on this.
3rd May 2019 2:02am |
Finally got the vinyl fitted to the spare door trims. Need to pop a few air bubbles and remove some glue residue that I accidentally got on the vinyl. Very happy with how it looks though. I wasn't sure if it would look ok or not, but I think it's subtle enough.
3rd May 2019 6:36pm |
1 side is done, Vinyl wrap is fitted. I am happy with the new look, not perfect, but not bad I don't think for someone with tremors, doing it between heavy rain and hail
4th May 2019 7:53pm |
