![]() | Home > Maintenance & Mods (L322) > Which Screen Wash? |
Personally in the summer I use Sonax Clear View screen wash. Great performance and very ecconomical, one bottle lasts me all summer and has an easy to use measuring dispenser.
Sonax & Meths mixed with water. |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Decasol for me |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
tap water with a slight touch of fairy liquid....
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Land Rover fill it up every service...
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
You's doing some dry miles there bud. 15MY SDV8 Vogue SE |
It's the weather down here. I've only used the screenwash a few times in the last month.
Make sure you something that kills Legionnaire's disease if you do not use it often! |
I find Legionnaire's really hard to remove, is there anything specific one can use to get rid of them? ![]() |
Not sure if your jesting but if your not removing tank and flushing with Boiling water & Detol is the best action to take other wise insert a hose and let it flush out with Detol or similar added.... |
Preliminary research by the Health Protection Agency suggests that in order to protect themselves from Legionnaire’s Disease, drivers should always remember to put screen wash in the reservoir which holds the water that washes the car windscreen. Following higher than usual incidences of the disease in the summer of 2006, a study undertaken showed that for some reason there was a particularly high incidence of the disease among professional drivers. It was then found that there was a strong correlation between non-professional drivers and a lack of screen wash in their windscreen water reservoirs. Although drivers could have been contracting the disease from exterior sources where the Legionella bacteria likes to breed, such as air-conditioning units, showers or cooling towers, they could just as easily be getting a dose through open widows or air vents whenever they cleaned their windscreen. Legionella bacteria breed in warm, stagnant water and are then spread to humans when suspended in droplets of water which hang in the air to be inhaled, exactly what is caused by aerosol systems like air-conditioning, or the fine spray produced by a windscreen washing device. Although more research needs to be done to find out whether or not screen wash was preventing the Legionella bacteria from breeding, a separate investigation conducted by the Environmental Protection Agency, has shown that one-in-five cars tested came up positive for Legionella in the windscreen reservoir. Of all the cars tested, none of those in which the driver was using a screen wash in the water, had any trace of the disease. |
Thanks Fox |
Lol, I actually thought you were jesting - seems not. What if someone in front of me uses their washer and I get sprayed with it? Can the pollution sensor be programmed to be a bio-hazard sensor too? I have now repeated this incredulous fact around work - no one else seems bothered at the fact we might all die from our screen wash! Well, except 'Slim Deb', but to be fair the pies are guna get her first. ![]() |
