|  | Home > Technical (L322) > Fuel burning heater..... |
| Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50      | They come on to speed heat the interior so it'll take a while to heat up if you pull the fuse. They tend to smoke because they don't get a lot of use
|  6th Feb 2017 10:10pm |
| MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81      | It's been cold alot lately so it's been kicking in every morning, and smokes everytime   | ||
|  6th Feb 2017 10:31pm |
| Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50      | I think there is a timed climate setting in the dash display. So you can use it when parked and not have the engine running. You can also set a time for it to come on. 2018 L405 Autobiograpghy
|  6th Feb 2017 10:42pm |
| MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81      | Yep I've seen that on the screen, it's says 'auxiliary ventilation '....... is that the FBH then chap ??? | ||
|  6th Feb 2017 10:47pm |
| Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50      | I think so. Have a play with it. Should have two time settings. But if the engine is not run in a 24 hour period it won't work. Saves to battery going flat 2018 L405 Autobiograpghy
|  6th Feb 2017 10:54pm |
| MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81      | I'll give it a whirl at the weekend and see how it goes... is it worth running some injector cleaner through the fuel tank do you think ??? | ||
|  7th Feb 2017 9:14pm |
| Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50      | Wont do at harm... 2018 L405 Autobiograpghy
|  7th Feb 2017 9:23pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | Aux ventilation is for hot weather.
|  7th Feb 2017 9:31pm |
| MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81      | Ummmmm..... Can't say I've seen 'aux heating' on my screen to be honest, just 'auxiliary ventilation " | ||
|  7th Feb 2017 9:34pm |
| mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 118      | If it's not there then it can be enabled using IID or similar.
|  8th Feb 2017 9:56am |
| vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110      |
 wish mine would smoke then id now its working   | ||
|  8th Feb 2017 12:03pm |
| Posting Rules
 occasionally and I find it quite embarrassing. This week in the drive through queue for instance, I was actaully asked if my car was on fire
 tried direct on aux heating and put it on timed nowt :cry:got the basic iid but thats got no test for my year 2003
