![]() | Home > Technical (L322) > 2009 interior upgrade for my 2003 ffrr |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi mate, well i went on a test drive this afternoon in a 2008 TDV8 with the new style seats and you are correct the new style seats are rubbish compared to my current BMW comfort seats. *Update* After a lot of research and consideration on this project i have decided that 'technically' it is possible to transplant the new style interior from a 07 onwards donor car in to a 02-05 vehicle, as everything 'cosmetic' from the donor vehicle still runs on the original BMW iBus network, inc lights, HVAC, BCU etc.. The only thing that runs on a different network that would be transplanted is the infotainment system which runs on the MOST fibre network and this can be linked to the iBus network with the 'Gateway ECU'. The only thing that really has caused me to scratch my brain is the airbag problem and because of this major issue i have decided that i will not be attempting this project at the moment. On the other hand i am going to be installing a OEM grade carpc into the range rover to replace the old BMW style screen and navigation system. I am going to be documenting the progress on this project here http://www.mp3car.com/vbulletin/worklogs/1...stall.html The new car pc i am building will use the touch screen from a 05-09 range rover and i am planning to remove the original land rover touch screen and fit a 7" TFT touch screen running on a custom car pc installed in the entertainment compartment in the rear. The user interface of the carpc will be Ride Runner running a custom Range Rover 2010 skin that i have created, if you check out the link above there is a sample of what the skin looks like! I am not planning to replace the sound system in the car (yet?) but i am going to be fully integrating the carpc into the range rovers electrics to control things like the original radio, onboard computer, instrument cluster - the steering wheel controls and the buttons on the front of the range rover nav screen will also be integrated into the system - the system will look totally OEM but give me much more functionality! I would like to thank everyone who replied to this thread on the interior upgrade and if i ever find a way to solve the airbag problem this project will be back on! *PS* - If any one has a nav screen from a 05-09 Range Rover that is faulty or does not work and you want to get rid and make a few quid will you PM me as all i need is the frame from the screen so the paint on the frame need to be not damaged. Thanks Matt Last edited by mattstevenson2005 on 4th Jan 2011 8:37pm. Edited 1 time in total |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi matt. the screen shot looks good, what will be unber 4x4.. and there was no section for computer, ie trip, fuel ect
Not decided yet, i will more than likely rename that label to something like Vehicle Info and put all the trip computer, fuel info in there. I just put the 4x4 Info label on while i was copying the original design. There is no 'program' as such, all the screens like the sample one are custom designed in photoshop from photos of the user interface on the 2010 range rover, then imported into the Ride Runner Skin Editor Tool and the functions added to the design e.g. button presses etc.... On your carpc do you use the CIS-IBUS unit to connect your pc to the factory screen? I am exactly the same as you i want to keep the factory options too. My plan is to recreate the 'original' BMW interface and features in ride runner and use the ibus interface to 'read' the values from the multiple ECU's on the ibus network. This project is very easy to do compared to the interior upgrade, in fact i have already built and tested some of the user interface and tested some of the ibus commands by connecting my laptop to the car and at the moment it is working. The hardest part is going to be integrating the BMW radio module into the pc as my plan is to create a radio screen on the pc and then the software will query the radio module over the ibus for the stations that are in range of the car and allow the user to scroll the list and select the station then override the sound coming from the pc and play the sound from the radio. I am using the BM54 radio module as a AUX IN to the range rovers sound system for the pc sound so selecting the radio option on the pc should allow me to just to change the audo source on the radio module, but i have not tested this theory out yet Matt |
I went through all the same thought processes - except for the late interior. I started with an MID RR and ended up retrofitting the BMW based nav on top of which I'm now adding my CarPC (it's been in the works for a while |
That's what I get for keeping the window open so long w/o posting... I believe daveo is using the Resler iBus interface and a VGA to NTSC convertor going into the reverse camera input on the TV module. I've used that too but now have the CIS. One of the main reason I decided to stay with the oem system and add is that I wanted to stick with the oem sound system too. Are you a member of the hack-the-ibus group yet. Good info there if you're planning on trying to control the radio via pc. After modifying my nav fw I have speed cam alerts, etc and am quite happy - so I'll be sticking with that too. I do want real off-road nav and ipod/iphone integration as well. We'll see. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Its great to see so many people modifying there range rovers!! some people have the idea that because these vehicles are so expensive you cant make modifications or improvements as nothing will work lol! My plan is not to lose any of the original functionality at all in fact you will still be able to control every aspect of the original system (sound, OBC, radio, CD etc...) from the carpc display. You will also be able to control the system from the buttons on the front of the land rover touch screen panel as i am planning to re-wire the buttons on the panel to a HID controller so that i can have both hard and soft buttons just like on the OEM system. e.g. the power button on the front of the panel will provide a way to control the power for the carpc - the pc will start booting when the doors are unlocked but if the needed can be force shutdown with this power button - also the the audio buttons on the panel will control music tracks, radio stations etc... just as they would normally on the OEM system.
I have a SSD as well - more for reasons of reliability than speed tho.
i use carx on the ibus, restler interface that looks for the tape command and when it see's it switches the the monitor to reversing input via a ground wire, this then displays the pc carx on the monitor, the switch is fautles
