Home > Technical (L322) > 2009 interior upgrade for my 2003 ffrr
Page 2 of 3 <123>
daveo
the early stuff is ibus and yes you need to get your hands on that all important gateway module, this was indeed used on the 2005 models and are as rare as, so if you have a source please put me down for one.
the seats will fit, the door trims will fit the pillar trims will fit.parcel shelf and carpet will fit even the rear quarter glass will fit..on the later cars a lot of the loom plugs change but this can be overcome.
the centre consol will not fit as yours and mine have the bmw gearbox and as stated the jag box gear stick is in a different place.now the dash i cant see fitting as the hole hav system is different and would be a nightmare to do. again with the later steering wheel it has a different language
you need to over come the can bus as this is used on the newer cars and the gateway module is your first step.. but good luck you will have plenty of people following you, inc my self.. V8 facelift Range Rover Autobiography 22" wheels.
Post #44262 2nd Jan 2011 10:03pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi Daveo, yes you are correct about the rare 'gateway ecu' P/N YWC500422 but you should be able to get one of these from a land rover dealership for around £300. The gear shift is not actually physically attached to the gearbox it is bolted to the centre console reinforcement and a cable is attached to the gearbox to allow the gear shift to operate. The 09 centre console reinforcement will allow it to be move, the only issue with this is the manual hand brake needs to be accommodated, which should be possible with the removal of the 09 e-brake control (along with a bit of custom trim modification) With regards to the nav unit Colin from Blackbox Solutions is currently working on this project to 'transplant' the touch screen infotainment system into the earlier vehicles, but as i would be swapping my current dash and dash reinforcement for the 09 on the 09 dash will fit just as it does in the original 09 vehicle.
The steering wheel buttons on the 09 vehicle run on the same ibus network as in the 02MY vehicle, it was only on the 10MY vehicles that the design of the wheel controls changed and now they run on the CAN bus network. Im glad that this project has sparked interest as im sure if i decide to proceed with the upgrade i will need to call on everyones expertise!
Matt
Post #44263 2nd Jan 2011 10:30pm
DMRR
So you are not going to a 2010MY interior, but a 2006-9 interior without the TFT dash? Just so I am following this correctly..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #44264 2nd Jan 2011 10:33pm
mattstevenson2005
Yes you are correct im going to the 09 spec (pre-TFT dash) - upgrading to anything after 09MY is not possible at the moment as all Range Rovers that are built with the 10MY spec now use the CAN bus network for communicating between its ECUs and the majority of the BMW communication buses have now been removed, meaning our existing ECU's would not be able to communicate correctly.
The most common item that people would won't to use in their pre 10MY vehicles is the redesigned steering wheel controls, which now runs on the CAN bus network, where as pre 10MY the buttons still operated on the traditional BMW ibus network, on the 06/07+ vehicles the instrument cluster is used as a gateway between the CAN and iBus networks. This is why the infamous 'gateway ecu' in the 2005 version is so rare as when Land Rover did the upgrade in 06/07 this temporary CAN bus gateway was replaced by the re-designed instrument cluster which incorporated this essential ECU. When BMW sold Land Rover to Ford, Ford wanted to replace the BMW infotainment system with a denso unit which is also used in the higher end Ford (among other vehicle manufactures) models so they designed a temporary 'gateway' ECU to translate the iBus commands of the BMW systems into their standard CAN commands which the new infotainment system uses to communicate.
Matt
Post #44265 2nd Jan 2011 10:50pm
DMRR
Hmmm well tbh, I wouldn't attempt the change, I had a 2004, a 2006 and now a 2010. The only major change was the 2010. I don't think it is worth the pain to change the entire interior, and the 2009 seats are *worse* than the 2002-2006 BMW ones......
That's just my opinion though Smile
Just do what Daveo and elpedee have done and get a carputer fitted. It does more than the 2009 system.....and will cost a damn sight less Thumbs Up Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #44267 2nd Jan 2011 11:04pm
mattstevenson2005
The reason i want to change the interior is because i much prefer the look of the upgraded interior over the 03 spec one. I was originally contemplating another in car pc (i have already had one in my previous car) but i decided against it as i like things to looks original as possible and doing the 09 upgrade gives me an original factory look with the upgraded infotainment system over the 03 spec. In the future i could do a in car pc on the touch screen system as you can use a VGA input converter to override the NAV display on the front screen. This is a very common upgrade on the RRS & Disco 3&4.
A number of people have said about the newer shape seats, so I think i am going to make a trip to my local dealer to try the seats out for myself as i really do like the comfort of my current seats.
Im very grateful for your comments because as you have said you have had every version of the L322 Range Rover and that gives me a great resource as you have 'lived' with the interior that i am looking at upgrading too. Hows the 2010 V8 to drive, that is the model i would most like to have - if i won the lottery i would be down the dealership placing an order straight away!!
Matt
Post #44268 2nd Jan 2011 11:24pm
DMRR
I really would check out the seats, also look at one with about 40,000 on the clock and notice the damage ... the leather is softer. They do not have the same amount of adjustment as the pre-2007 either. I was lucky that my 2006 was an early one with the manual handbrake etc, and BMW seats still. 2004 and my 2006 had more comfortable seats than my 2010.
The engine/gearbox is much better in the 2010. Very smooth and very quick. Best vehicle I have driven - would be better with my 2006 seats tho! Big Cry
I know where you are coming from - but I did the exact opposite with my Discovery. I swapped the engine and eventually gearbox, for a 4.6V8 Wink Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #44269 2nd Jan 2011 11:30pm
daveo
matt, so you are going with the 09 steering wheel controls, now are thes the same as the earlier models or as they started fitting the new style steering wheel controls with the 4 way thumb swithes at the top, as these are what i have and was told they are can bus. V8 facelift Range Rover Autobiography 22" wheels.
Post #44270 2nd Jan 2011 11:47pm
DMRR
Daveo, if pre-2010 TFT etc, they will be as the 2006-2009 MY was..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #44271 2nd Jan 2011 11:51pm
mattstevenson2005
The ones that are on the current range rover model with the thumb switches at the top, run on the CAN bus network, any other model years e.g. 05-09 still use the BMW ibus network to send their signals to the instrument cluster gateway which sends it to the infotainment system (touch screen version) 02-04/05 (pre touch screen) the steering wheel buttons connect directly to the infotainment ibus network.
Post #44274 3rd Jan 2011 12:15am
SteveMFr
Site Sponsor
Sounds ambitious, to say the least, Matt.
The biggest problem you're going to face, is that the later RR has a second CAN bus added. And AFAIK the gateway ecu only goes between the MOST bus/I bus (Infotainment), and the medium speed (MS) CAN, not HS CAN to MS CAN. This is the job of the newer instrument cluster (IIRC - no guarantees. I suffer from CRS). Most of the vehicle critical systems on the later RR (ABS, Airbags, DSC, EAS, etc, etc) are on the HS CAN - this is simply not on your RR yet and there are no provisions for it. The only ECU's you have in common with a post 06 are the BCU and LCM and non critical items such as the FBH if fitted (IIRC, as stated above). All that said, anything can be done with enough time and money and maybe Colin will be able to give you a better solution, but I believe it might be easier to purchase a totaled 06 or later RR and swap everything including motor and transmission to your body. And then we get back to the economics of a swap like this... Shocked
As long as Colin hasn't answered, check the Blackbox site. Under 'Downloads' there is some very good info on the various busses, ECU's etc.
If I were to have to try something like this, I'd probably stick with the original electronics and adapt the switches/etc. I'd especially leave all original SRS/airbag items in place - which of course creates huge problems with the dashboard/glovebox, doorcards, etc as there are no provisions for releasing the original airbags in the later bits...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #44312 3rd Jan 2011 4:08pm
mattstevenson2005
Hi mate, you are correct about the multiple CAN networks, but everything i want to add either runs on the existing networks or on the MOST bus for the infotainment system - the donor car i have is a front end smashed up 2009 so i am planning to just swap everything 'cosmetic' from the 09 to my 03. I have been talking with Colin because as im sure your aware he's doing the same project with putting the touch screen nav system into his 03 vehicle so he has some excellent experience in this field. My most difficult problem as mentioned in previous posts is the redesigned airbags e.g. in 02-05 side air bags are in the door, 05-09 they are now in the actual seats, and also the dash airbag has moved. Your also correct my plan is to try and stick with the original electrics and 'adapt' the new style switches to function with the existing systems. Apart from the MOST infotainment system everything else that will be transplanted from the 09 donor vehicle runs on either the BCU or LCM which can be simply swapped from the 09 vehicle and re-configured using my MSV2-Extreme from Blackbox.
Matt
Post #44332 3rd Jan 2011 5:27pm
SteveMFr
Site Sponsor
That's a bit of a problem, tho.
In the P38, the crush cans behind the bumper made mounting a winch a complicated affair with sliding brackets, etc. If the winch were to be mounted solidly in front of the bumper, it would throw the airbag release timing off due to the crush cans being deleted. It's that accurate. So there is no way to use the original airbag ecu, even assuming you could adapt it to ignite the seat bags. Release timing would be way off. And the airbag ecu is on the HS CAN. I thought you were going to try to add the terrain response ecu too - did read that you said it may not work.
What's Colin saying to all this - quite curious?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #44390 3rd Jan 2011 9:02pm
Andy
I stopped reading at the 2nd paragraph and I'm a time served engineer!
Seriously- I wouldn't bother. Get an 07 car thats been built not bodged. You'll never sell it either. Airbags are going to be part of the MOT soon as well, so I'm guessing (and I'll stand corrected due to lack of knowledge) that newer, retrofitted seats with airbags in them will be subject to an engineers report pre MOT.
Having worked on CANBUS systems on multi-million pound materials handling systems, all I can say is best of luck! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #44436 4th Jan 2011 1:42am
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Matt,
Have you discussed how you will be able to interface with the new modules in the old car with Blackbox?
It might be tricky because your active Faultmate System will only have the modules from the old car working. When I replaced the Mk3 Satnav in mine with a Mk4,I could no longer read it with Faultmate. I'd guess you'll have similar issues with loads of modules and might even create hybrid systems that Faultmate won't recognise?
Even that part of the exercise could be expensive if you have to buy two separate single vehicle licences for your Faultmate.
Good luck though!
Post #44446 4th Jan 2011 9:19am
Page 2 of 3 <123>
