![]() | Home > Technical (L322) > 2009 interior upgrade for my 2003 ffrr |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I am not technical so excuse the lack of input but I rather hoped you could send me some of what you are smoking?
Wow, that certainly is ambitious. I can se where you're coming from, there are a lot of nice interior touches in the newer models.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi Dan, thanks for your comments, yes the terrain response dial is one of the things that may not work, although i am hoping that with alot of work and use of my knowledge and my MSV2 i will hope to eventually to try and get this work (or at lease get the HDC and air suspension buttons to work) to start with i will be leaving the bottom centre console panel in place so i could continue to control the EAS modes. The 2009 seats still run on the BMW ibus network even in the 2009 model so hopefully with a bit of work these will work just as they do now. My only concern with the seats is the SRS system, same as the airbag in the dash. The light control module (LCM) is the same as what is in the 03 model (apart from it is a different revision) so with changing the LCM from the 09 car into the 03 car there should be no problems also transplanting the rain/light sensor and light switch in to the 03 car will give me auto lights which i don't have now. I forgot about this feature my car has had the 07 front and rear facelift so my car has the adaptive lights fitted already so in the future this could be a separate project to enable this function on my 03 car. Resale value is not a concern for me as even leaving the car in is current state (which is absolutely mint inside and out!) will still drop like a stone over the next few years even more so when the 'new' 2012 range rover comes out. I have read both those forum posts over and over again in the preparation to this project, Colin's ambition is to get all aspects of the entertainment system working with his current 03 model e.g. 4x4 screen etc... so i am hopeful that once Colin figures it all out i can just follow his lead. If i do go ahead with this project i will post all the details and photos on my website www.myrangerover.co.uk Thanks again Matt |
It's also worth noting that the LCM stores a copy of the Mileage data - so as long as you get the binnacle and the LCM from the same donor car you "should" be OK. However, I have heard than the ECM also stores mileage data, but this is un-verified so far.
Hi Dan I will be getting both the LCM and binnacle from the 2009 car but as far as i am aware you can't use the new 07+ shape binnacle on a 03 engine ECU (not 100% on this though, would like to use the newer binnacle but i am assuming this cannot be done, but would love to be proven wrong!!) with regards to mileage data i remember reading somewhere that the actual key/binnacle/LCM and EMC stores the mileage data and if the binnacle and LCM readings dont match you get a black dot on the screen indicating that they may be a discrepancy between the 2 ECU's. I was hoping that once i connect the donor LCM up to the car it would take the readings from my current binnacle as it will have a higher millage than the donor LCM unit. This is the same procedure that happens when replacing a damaged binnacle the replacement unit takes the highest millage recorded on in the car. The seats in the donor car are heated only and use the same control panel in the centre console as my current seats so im hoping for a simple plug and play option. The front end conversion was already done on the car when i purchased it and it dose have the cone type air filter. Another project on my list is to 'construct' as bulk head between the engine and the air filter to prevent the engine sucking in warm air, but this is for another time. Matt |
The reason I ask about whether you did the conversion or whether it was a rip off merchant... is because whoever did mine (before I bought it) and put the cheapest possible lights in. So are you 100% sure you have adaptive lights? Mine should have bi-xenon, but they only fitted Xenon, then sold my Bi-Xenons... as well as a load of other bodges. I'd be interested if the door cards are a strait swap - I prefer the newer door cards to mine... ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35793 ![]() ![]() |
the gear shift on the 2003 is in the middle so the later console wont fit as the shift is more to the driver..
Hi scarey, yes im Matt from rr.net and Landyzone, I have though about that problem too, the reason it is more to the drivers side is because the centre console reinforcement has a slightly different design so swapping the actual reinforcement for the centre console to the 09 one will allow me to mount my gear shift on the drivers side then i will modify the electronic parking brake area to allow my manual parking brake to come though when the e-brake button is. I will double check the spec on the lights. With regards to the door cards, it should be a straight swap as the buttons on all the doors are the same from 02-11 and the 09 car is essentially the same as the 02 in regards to shape. e.g 02 door cards are same as 09 etc.... Matt |
thought is was you, welcome mate....
cheers scarey!! thanks for the welcome!
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
the door cards are different in the later model due to the airbag being in the seat and no longer in the door , but they will fit, you just have to figure out how to wire the seat airbags up and remove the unused ones out of the door 2002 td6 vogue, 06 supercharged facelift
Ah really? That's a pain. ![]() |
im going to purchase a subscription to Topix so i can take a look at all these little details and i can start to work out my game plan for the upgrade and i can compare the wiring diagrams from the 03 to 09 models
Not to chuck a damper in, but if you are going to start playing with airbags, construction and use will rear it's ugly head. You can't mess with the safety systems of a modern car and expect your insurance company to play ball....
