Home > Technical (L322) > Towing electric module and different plugs???
andygts
Are the control modules different?
I've currently only got the single 7 pin socket and could do with upgrading to the 13pin socket.
Is it as simple as order a plug and loom and swap over? Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #437025 4th May 2017 8:53am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Don't be silly - it's a RR.
I don't actually know the answer by the way...
Post #437055 4th May 2017 1:26pm
Clivefog
United Kingdom 2003 Range Rover Vogue 4.4 V8 Java Black
Yes, the 13 pin one is a replacement for the old black and grey 7 pin (dual) sockets.
You will need to add a switching relay for the caravan battery charging feed so you don't drain the engine battery, may come with the new socket?
Post #437057 4th May 2017 3:19pm
andygts
I only have single 7 pin. No caravan socket.
Got a feeling this may cost.
The towbar is a non gen removable swan neck, I'll guess that the electrics will be non gen too come too
Not sure which wire needs a relay, I've no intention of attaching a caravan to it (can't stand the things) I need the extra 12v power feed though and the addition of reversing lights would be nice. Current
Previous
Post #437058 4th May 2017 3:34pm
Clivefog
There you go -
http://www.practicalcaravan.com/advice/284...-electrics
Post #437063 4th May 2017 3:45pm
